EPiServer.Global.EPDataFactory.SavedPage += new EPiServer.PageEventHandler(Newsletter_SavedPage);
to the InitializeComponent-method in my Web User Control. In this way the Newsletter_SavedPage-method will only be called when the current page is saved.
My problem is that this event is called after the page_load-method. I want to do some text-processing in the savedpage-event and save the text in a property. In the page_load method I then want to fetch the generated text from the property. But as said, the order is now opposite.
If I put the SavedPage-event handling in the global.asax as you recommended, will this event be called before the page_load-method in my Web User Control? If so, that could be a solution.
Best regards
Bård
