DXP Commerce/CMS11 deployment warning: The Azure Health Check feature is not working as expected
I'm looking at a CMS11 & Commerce Connect environment DXP deployment that has these warnings logged:
DXCS009, The source is missing assemblies needed for compatibility in DXP. Details: missing the Episerver.CloudPlatform.Cms.dll file, https://docs.developers.optimizely.com/digital-experience-platform/v1.3.0-DXP-for-CMS11-COM13/docs/requirements
DXCS007, The source is missing assemblies needed for compatibility in DXP. Details: missing the Episerver.CloudPlatform.Commerce.dll file, https://world.optimizely.com/documentation/developer-guides/digital-experience-platform/requirements/
Failed to validate default hostname ***prod-slot.dxcloud.episerver.net for the slot slot on site ***, falling back to ***prod-slot.azurewebsites.net
The Azure Health Check feature is not working as expected.
I'd prefer not to install the first two packages/DLLs mentioned since I've heard they can really mess things up...
But how can solve the last warning? Is that something that normally is handled inside the CloudPlatform-binaries?
#339542
Jun 26, 2025 13:31
Hi Johan
Apparently those assemblies are optional. However, I like having them so all the integrations are set up automatically in DXP. When "self-hosting" in Azure, it is a whole other story.
The DXP documentation warns that you will get a warning. Probably the one you get.
If you really don't want to install those assemblies, you might have to emulate the health check endpoints (see EPiServer.CloudPlatform.Cms.Internal.CloudPlatformHealthCheckEndpointRoutingExtension and Microsoft.Extensions.DependencyInjection.WarmupHealthChecksBuilderExtensions) so DXP sees what it wants.
#339547
Jun 27, 2025 13:32
Johan Kronberg - Jul 01, 2025 6:49
I looked around in the packages and it seems they are more "isolated" in regards to Web API config now. Also quite lightweight for Full Framework.
