UnAuthorize then asking to Commerce serviceAPI
I have strange behavior...
I am getting the token with httpClient, and all looks fine. I mean I am getting the access token.
When I use the token, for getting all nodes (HTTPS://www.testserver.se/episerverapi/commerce/catalog/{catalogname}/nodes) I am getting unauthorized from serviceAPI. I can only get the token from ServiceAPI when using httpClient.
I added this to my StartUp
app.UseServiceApiMembershipTokenAuthorization();
The strange thing is when I am using Postman with the same credentials that I am using in httpClient, first get the token, and then use it for getting the nodes (in this case), works fine, but not when I am using in code.
The URL looks good, is the same as in Postman
I have also added the user in Access to Function in Admin, otherwise, it wouldn't work in Postman.
ServiceAPI version: 5.6.1
ServiceAPI Commerce version: 5.6.1
EPiServer: 11.28
EPiServer Commerce: 13.23
Still using .net 4.7
#291844
Edited, Nov 17, 2022 22:32
I think you have to add the bearer like this
    client.DefaultRequestHeaders.Add("Authorization", "Bearer " + accessToken);
#291881
Nov 18, 2022 7:36
Hi Quan
Still the same problem...
#291889
Nov 18, 2022 11:15
Did you check the request headers? How does it look like?
#291891
Nov 18, 2022 12:03
Yes, its in place...
#291893
Nov 18, 2022 12:34
Please make sure you have the last backslash after nodes/
I'm guessing here but worth a quick try ?
#291894
Nov 18, 2022 13:18
Sounds like Postman is redirecting automatically to a new address, that's why it works, but when using httpclient.
Any idea?...
I also tried to add a "/" at the end, but the same problem.
#291897
Nov 18, 2022 13:41
ok so httpclient will loose headers when it gets redirected. You need to make sure you request the dev. url directly
#291898
Nov 18, 2022 14:06
Yes, I am trying to figure it out what the URL is...
#291900
Nov 18, 2022 15:20
isn't it dev.something.com:443?
#291902
Nov 18, 2022 15:44
I added the rigth url and it works, I also noticed that is case sensitive.
#292342
Nov 28, 2022 16:03
