Check the state of the variant you are trying to add to the cart. If it's invalid in any way, it will get removed from the cart.
I.e. Inventory is zero, item availability has expired etc
Hi Jonathan,
Check with the below code:
CartHelper.Cart.RunWorkflow(Constants.CartValidateWorkflowName);
We have a 7.5 Episerver CMS and Commerce.
The site has worked for over 8 years – and suddenly on the 16th Jan 2022 the commerce side of the website stopped working.
When we add in an item to the Cart the cart is full – when it hits ListItemsSimpleView.ascx.cs in the BINDDATA method the Cart is still full but as soon as it hits this function
CartHelper.RunWorkflow(Constants.CartValidateWorkflowName); - the workflow name is “CartValidate”.
The Cart is empty
I have rolled back the code to a code sample of 2020 (2 years old) and it still throws the same error. Which is very odd.
Can I ask – does CartHelper.RunWorkflow (which is part of Mediachase.Commerce.Orders.Managers) talk to any external APIs such as FIND or any EpiServer API that may have stopped working/de-commissioned OR changed?
SAMPLE OF CODE
private void BindData()
var isEmpty = CartHelper.IsEmpty;
// Make sure to check that prices has not changed
if (!isEmpty)
// restore coupon code to context
string couponCode = Session[Constants.LastCouponCode] asstring;
if (!String.IsNullOrEmpty(couponCode))
MarketingContext.Current.AddCouponToMarketingContext(couponCode);
CartHelper.Cart.ProviderId = "FrontEnd";
// If cart is empty, remove it from the database
if (isEmpty)
CartHelper.Delete();
CartHelper.Cart.AcceptChanges();
if (!isEmpty)
string ProductName = "";
try
foreach (var v in CartHelper.LineItems)
var ce = CatalogContext.Current.GetCatalogEntry(v.ParentCatalogEntryId);
if (ce != null)
if (ce.Name != null && ce.Name != "")
ProductName = ce.Name;
break;
if (ProductName != "")
litEventName.Text = "<h2>" + ProductName + "</h2><hr/>";
catch (Exception ex)
SendUserEmail(ex.Message, "ERROR BINDING");
lvCartItems.DataSource = CartHelper.LineItems;
_promotionResult = CartHelper.GetPromotions();
lvCartItems.DataBind();
