I haven't seen this, but have you tried to replace the entire Apps folder of Commerce Manager? It's possible that one or more files were missing/corrupted.
Thanks Quan, that did seem to help a bit. The same error still persistsm althoug less frequent and with a completely different error message:
System.Web.HttpUnhandledException (0x80004005): Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at Mediachase.Commerce.Orders.OrderForm.CreatePayment(String type)
at Mediachase.Commerce.Orders.OrderForm.LoadPayment(DataRow[] rows)
at Mediachase.Commerce.Orders.OrderForm.LoadPayments(DataTableCollection tables, String filter)
at Mediachase.Commerce.Orders.OrderForm.PopulateCollections(DataTableCollection tables, String filter)
at Mediachase.Commerce.Orders.OrderGroup.PopulateCollections(DataTableCollection tables, String filter)
at Mediachase.Commerce.Orders.OrderGroup.PopulateCollection[T](ClassInfo classInfo, MetaStorageCollectionBase`1 collection, DataSet dataSet)
at Mediachase.Commerce.Orders.PurchaseOrder.Search(OrderSearch search, Int32& totalRecords)
at Mediachase.Commerce.Orders.OrderContext.FindPurchaseOrders(OrderSearchParameters parameters, OrderSearchOptions options)
at Mediachase.Commerce.Orders.OrderContext.GetPurchaseOrderById(Int32 orderGroupId)
at Mediachase.Commerce.Manager.Apps_Code.Order.OrderHelper.GetPurchaseOrderById(Int32 orderGroupId)
at Mediachase.Commerce.Manager.Apps.Order.Modules.OrderView.LoadOrderGroup(Guid customerId, Int32 orderGroupId)
at Mediachase.Commerce.Manager.Apps.Order.Modules.OrderView.LoadContext()
at Mediachase.Commerce.Manager.Apps.Order.Modules.OrderView.Page_Load(Object sender, EventArgs e)
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
Looks like a problem with your order. I can't say which, I'd suggest to contact developer support service for assistance.
When an order is clicked, the request going to http://manager.mysite.com/Apps/Asset/Tree/TreeSource.aspx fails and the log shows the following:
System.Web.HttpParseException (0x80004005): Could not load type 'Apps_Asset_Tree_TreeSource'. ---> System.Web.HttpParseException (0x80004005): Could not load type 'Apps_Asset_Tree_TreeSource'. ---> System.Web.HttpException (0x80004005): Could not load type 'Apps_Asset_Tree_TreeSource'.
at System.Web.UI.TemplateParser.GetType(String typeName, Boolean ignoreCase, Boolean throwOnError)
at System.Web.UI.TemplateParser.ProcessInheritsAttribute(String baseTypeName, String codeFileBaseTypeName, String src, Assembly assembly)
at System.Web.UI.TemplateParser.PostProcessMainDirectiveAttributes(IDictionary parseData)
at System.Web.UI.TemplateParser.ProcessException(Exception ex)
at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding)
at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding)
at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath)
at System.Web.UI.TemplateParser.ParseInternal()
at System.Web.UI.TemplateParser.Parse()
at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType()
at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider)
at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders()
at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean throwIfNotFound)
at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp)
at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
at System.Web.HttpApplication.MaterializeHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
This happens periodically, it works fine for a few hours, then does this for 30 minutes. Spamming refresh sometimes help
Commerce version is 12.41
Has anyone experienced something like this?
