Although Nodes, metaclasses, and meta fields have clear representation in the database but Episerver supports the code first approach.
However, you can write a service API that can create meta fields and metaclasses based on request. (useful if you have master & slave catalogue structure)
Not sure what you meant "epi commerce api", but you can use MetaClass and MetaField class (in Mediachase.MetaDataPlus.Configurator namespace ) to create metaclasses and metafields (and to link them together)
You can just write extensions to ServiceAPI (it's "just a REST endpoint"), using MetaClass and MetaField under the hood to do the same. But it's not available out of the box
We have a PIM, in which we set our model structure. This we want to push into epi commerce. Is it possible to create metaclasses and metafields via the epi commerce api?
Thanks in advance!
