Access control for individual Navigation elements in Catalog Management
Commerce Manager Version: 11.19
There was a requirement that
  1. User A have access to Normal Product
  2. User B has access to Licensing Product
  3. User C has access to Warranty Product
Where exactly in Episerver, the above three types of Products can be restricted !!
#249883
Mar 11, 2021 8:19
Unfortunately you can not do that in Commerce Manager. Access right to catalog in CM is all or nothing. You would have to use Catalog UI (cms) for that
#249886
Edited, Mar 11, 2021 8:32
You need to do it in catalog interface. You will setup access rights similar to cms pages
#249887
Mar 11, 2021 8:33
Thanks for the timely response, Could you please guide on achieving the same through Catalog UI
#250019
Mar 14, 2021 12:19
you can set access rights in Cms -> Admin -> Set Access rights (left panel)
Below is a link to the Episerver guide to set up access rights for commerce.
https://webhelp.episerver.com/latest/en/commerce/access-rights.htm
#250020
Mar 14, 2021 13:26
If you switch a catalog/node to All Properties mode, you can click on VIsible to: (someone) Manage to open this dialog
The access right setting is only per catalog/node. Entries will inherit the settings from its true parent.
If you want to manage it in code, use https://world.episerver.com/csclasslibraries/cms/EPiServer.DataAbstraction.IContentSecurityRepository?version=11
#250055
Mar 15, 2021 8:18
