Hi Mark,
I think we can published only saved content, so you can modify saveAction as following and then try:
ContentVersion product = _contentRepository.Get<ProductType>(latestVersion.ContentLink);
if (product != null)
var clone = product.CreateWritableClone();
SaveAction saveAction= (product as IVersionable).Status == VersionStatus.Published
? SaveAction.Save | SaveAction.SkipValidation | SaveAction.ForceNewVersion | SaveAction.Publish;
: SaveAction.Save | SaveAction.SkipValidation | SaveAction.ForceCurrentVersion;
_contentRepository.Save(clone , saveAction, AccessLevel.NoAccess);
looks like the error is within the products published with the previous version, and within service API, Maybe you have to raise a bug with the support
Hi Mark,
Is it possible the products that are throwing an error are in the middle of a CMS approval sequence workflow?
Please contact developer support service. It looks like a problem with your versions, but I'm not sure which
Episerver Commerce Version: 12.x
ServiceAPI Endpoint: episerverapi/commerce/entries/
Steps done to investigate
- Manual hit to endpoint with same payload, turns out to be working
We have episerver integration that calls episerver serviceAPI, at some point we encounter some data not updated. I found out that serviceAPI is failing, not all calls are failing.
