If I remember correctly you should also override the GetDiscountedPrice as that is used in calculating the orderfrm values
How do you register your CustomLineItemCalculator . Is it registered for Commerce Manager also?
I am working on Commerce 13.21.0. I am facing an issue where the cart total doesnt seem to be getting updated after overriding the LineItem calculator. I am overriding the CalculateExtendedPrice method of ILineItemCalculator to increase the extended price of a line item by $10 if a line item requires customization.
Above is the code, a straight forward override and I am also making sure that the CustomLineItemCalculator is registreted as the ILineItemCalulator implementation during initialization.
I can also see the extended price being computed properly in the DB:
But inspite of all this the cart total is still $170.
