Draft added when trying to create and publish content programmatically
When trying to create a commerce content programmatically using code similar to this
var clone = content.CreateWritableClone<CustomProduct>();
//Update clone properties here
var batch = new List<CustomProduct> { clone };
foreach (var branch in customModel.LanguageVersions)
    var branchContent =  contentRepository.Get<CustomProduct>(contentLink, branch.CultureInfo).CreateWritableClone<CustomProduct>();
    //update branchContent
    batch.Add(updatedContent);
_contentRepository.Publish(batch);
I get *two* versions of my content instances for each language except the main one.
One of them is in published state and created by "you", the other one is in a draft and created by "system".
When I open my product language instance I get to the draft by default where none of the properties were updated. If I then revert changes to published state - everything is correct.
Did anybody face the issue?
PS Tried to post a screenshot here. "Only users belong to partner companies are able to upload image files." - a bit annoying, isn't it?
#223961
Jun 08, 2020 16:28
Have you tried debugging, and checking the content of batch just before calling _contentRepository.Publish(batch);?
#223964
Edited, Jun 08, 2020 18:41
Yes, the content is okay. And actually if I revert to last published version then I get everything updated. So the problem is exactly in creating two instances (published and draft) for each language branch.
By the way, if I update the language instances one by one  contentRepository.Save(updatedContent, SaveAction.Publish, AccessLevel.NoAccess) I get the same issue. So this is not about batch only.
#224016
Edited, Jun 09, 2020 10:41
@Alex did you get to the bottom of this issue? I'm facing the same issue at the moment.
#255221
May 20, 2021 17:02
