Setting a NodeContent as the catalog root using the HierarchicalCatalogPartialRouter
I am trying to set the Node content as the catalog root. Below is my catalog structure:
https://www.screencast.com/t/5tMhOWSBJDk
I want to make the Test Node the root for all the children Node Contents under it. And below is my code
using System;
using System.Configuration;
using System.Linq;
using System.Web.Routing;
using EPiServer;
using EPiServer.Commerce.Routing;
using EPiServer.Framework;
using EPiServer.Framework.Initialization;
using EPiServer.Web;
using EPiServer.Web.Routing;
using Mediachase.Commerce.Catalog;
namespace Foundation.Infrastructure
    [InitializableModule]
    [ModuleDependency(typeof(EPiServer.Commerce.Initialization.InitializationModule))]
    public class Initialization : IInitializableModule
            var referenceConverter = context.Locate.Advanced.GetInstance<ReferenceConverter>();
            var contentRepository = context.Locate.Advanced.GetInstance<IContentRepository>();
            var rootLink = referenceConverter.GetRootLink();
            var root = contentRepository.GetChildren<EPiServer.Commerce.Catalog.ContentTypes.CatalogContent>(rootLink).FirstOrDefault();
            var rootNodeContent = contentRepository.GetChildren<EPiServer.Commerce.Catalog.ContentTypes.NodeContent>(root.ContentLink).FirstOrDefault();
            var hierarchicalCatalogPartialRouter = new HierarchicalCatalogPartialRouter(() => SiteDefinition.Current.StartPage, rootNodeContent, false);
            RouteTable.Routes.RegisterPartialRouter(hierarchicalCatalogPartialRouter);
            //Add uninitialization logic
But I still see the routing has not changed, it still is for exmaple: www.example.com/shopping/testnode/cookware/
Since I made the the first NodeContent the root, I was expecting it to be like: www.example.com/testnode/cookware/
Am I missing something here?
#222253
May 01, 2020 3:45
Hi Siddharth,
I have created another entry for Node in the RouteTable which works for both cases catalog and node. Please try.
e.g.
    public class CatalogRoutingInitialization : IInitializableModule
            // Services
            ReferenceConverter referenceConverter = context.Locate.Advanced.GetInstance<ReferenceConverter>();
            IContentLoader contentLoader = context.Locate.Advanced.GetInstance<IContentLoader>();
            // Register catalog router (removes catalog string from URL)
            ContentReference rootLink = referenceConverter.GetRootLink();
            CatalogContent catalog = contentLoader.GetChildren<CatalogContent>(rootLink).FirstOrDefault();
            Func<ContentReference> startLink = () =>
                ContentReference.IsNullOrEmpty(SiteDefinition.Current.StartPage)
                    ? SiteDefinition.Current.RootPage
                    : SiteDefinition.Current.StartPage;
            // catalog root content
            RouteTable.Routes.RegisterPartialRouter(new HierarchicalCatalogPartialRouter(startLink, catalog, false));
            // node root content
            var rootNodeContent = contentLoader.GetChildren<NodeContent>(catalog.ContentLink).FirstOrDefault();
            var nodeCatalogContent = contentLoader.Get<CatalogContentBase>(referenceConverter.GetContentLink(rootNodeContent.Code));
            RouteTable.Routes.RegisterPartialRouter(new HierarchicalCatalogPartialRouter(() => rootNodeContent.ContentLink, nodeCatalogContent, false));
For more customization please follow Jakejon's post.
#222275
May 01, 2020 19:18
- May 03, 2020 6:27
Hi Sanjay, I tried this out but it did not work as well. Have you tried this on Foundation? Looks like this is not working on Foundation.
Sanjay Kumar - May 03, 2020 16:54
No, I tried in QuickSilver solution.
It looks like you are using Foundation? Then you might want to remove this line
https://github.com/episerver/Foundation/blob/0604b691053359f7640ff4869494d2fe322b081e/src/Foundation.Commerce/Extensions/InitializationEngineExtensions.cs#L38
this registers the default router which might interfere with your set up
#222327
May 03, 2020 20:34
- May 03, 2020 23:36
Thanks Quan! :)
