Commerce manager is not opening
Hi ,
I have newly installed Episerver Commerce 13.15 in my local machine  .
In episerver Admin view at the top when I am clicking on "Commerce manager" tab , Its not opening . Its  showing message  that "cannot reach to this page".
Could  anyone please help me to resolve this issue.
Sourav
#217291
Feb 20, 2020 12:26
You will need to update the CommerceManagerLink in web.config/appSettings to point to the url of your Commerce Manager site
#217292
Feb 20, 2020 12:57
Hi Quan,
Thank you for your answer . Since I am new in episerver commerce I dont know which value need to be set in Webconfig file to see Commerce manager .
In Webconfig file  below has been set automattically. Please let me know what need to be changed there to see commerce manager
<add key="CommerceManagerLink" value="https://localhost:44341/" />
Sourav
#217293
Feb 20, 2020 14:09
You need to check which port your CM is using, by opening your CM project properties
Also as you are running IIS Express (assuming), you need to make sure your CM site is running
#217295
Feb 20, 2020 14:14
