Creating multiple sub node items with same name in different parent node using commerce service API
I am facing some wired issue while importing catalog and node items using Episerver Commerce service API
Scenario -
My Catalog
  • Node 1
    • Sub node
  • Node 2
    • Sub node
  • Node 3
    • Sub node
I want to create a node name called "Sub node" within different nodes but the API only creates "Sub node" once and returing success for all the node but I am not able to see the other sub nodes.
Any one have any idea on this?
#230245
Nov 02, 2020 15:12
just to be sure - did you set the sub nodes to have different codes?
#230246
Nov 02, 2020 15:44
No, in the current XML the sub-nodes have the same code.
<Node>
        <Name>Cleaners</Name>
        <StartDate>2020-10-24 08:33:00Z</StartDate>
        <EndDate>2030-10-24 08:33:00Z</EndDate>
        <IsActive>true</IsActive>
        <SortOrder>6</SortOrder>
        <DisplayTemplate />
        <Code>Cleaners</Code>
        <MetaData>
          <MetaClass>
            <Name>CatalogNodeEx</Name>
          </MetaClass>
          <MetaFields>
            <MetaField>
              <Name>DisplayName</Name>
              <Type>ShortString</Type>
              <Data language="fr-ca" value="" />
            </MetaField>
            <MetaField>
              <Name>Published</Name>
              <Type>Boolean</Type>
              <Data language="fr-ca" value="true" />
            </MetaField>
            <MetaField>
              <Name>Position</Name>
              <Type>Integer</Type>
              <Data language="fr-ca" value="1" />
            </MetaField>
          </MetaFields>
        </MetaData>
        <ParentNode>Accessories</ParentNode>
        <SeoInfo />
      </Node>
 <Node>
<Node>
        <SortOrder>32</SortOrder>
        <DisplayTemplate />
        <MetaData>
          <MetaClass>
          </MetaClass>
          <MetaFields>
            <MetaField>
            </MetaField>
            <MetaField>
            </MetaField>
            <MetaField>
            </MetaField>
          </MetaFields>
        </MetaData>
        <ParentNode>Room Air Accessories</ParentNode>
        <SeoInfo />
      </Node>
 <Node>
#230249
Edited, Nov 02, 2020 16:32
That will not work. Code is the identity of node/entry, so subsequent imports will just override the first one. If you want to have same name but different nodes, you have to have different codes.
#230251
Nov 02, 2020 16:40
Oh, I see. Let me try that.
#230254
Nov 02, 2020 17:11
It worked. Thanks.
One more thing when I try to update any existing node it basically overwrites the node and removes all the other language values.
Like in the below node structure first I create the "Filters" node and then for the second entry I fired the put call but it removed the values of en-us
<Node>
        <Name>Filters</Name>
        <StartDate>2020-10-24 08:30:00Z</StartDate>
        <EndDate>2030-10-24 08:30:00Z</EndDate>
        <SortOrder>2</SortOrder>
        <DisplayTemplate />
        <Code>Filters</Code>
        <MetaData>
          <MetaClass>
          </MetaClass>
          <MetaFields>
            <MetaField>
              <Data language="en-us" value="Filters" />
            </MetaField>
            <MetaField>
              <Data language="en-us" value="true" />
            </MetaField>
            <MetaField>
              <Data language="en-us" value="1" />
            </MetaField>
          </MetaFields>
        </MetaData>
        <SeoInfo />
      </Node>
<Node>
        <DisplayTemplate />
        <MetaData>
          <MetaClass>
          </MetaClass>
          <MetaFields>
            <MetaField>
            </MetaField>
            <MetaField>
            </MetaField>
            <MetaField>
            </MetaField>
          </MetaFields>
        </MetaData>
        <SeoInfo />
      </Node>
 <Node>
#230340
Nov 04, 2020 10:04
IIRC it is the default behavior. We talked about how we want to handle it, overwrite, or combine, but no decision has been made.
#230342
Nov 04, 2020 10:12
oh :(
so basically I have to merge my XML node first and then create the complete node once. right?
or is there any workaround for this?
#230348
Nov 04, 2020 10:45
yes, you need to merge the fields yourself
#230350
Nov 04, 2020 11:32
