metaClass.DeleteField(metaFieldName) should do the work for you. So basically
MetaDataContext metaDataContext = CatalogContext.MetaDataContext;
MetaClass metaClass = Mediachase.MetaDataPlus.Configurator.MetaClass.Load(metaDataContext, "metaclassname");
metaClass.DeleteField("metafieldname");
I am not able to delete MetaField programmatically, because said MetaField are linked to MetaClass/MetaClasses and therefore cannot be deleted. Below code works after removing the MetaField link to MetaClass/MetaClasses manually within the Commerce Manager, but I want to automate that process.
I have read threads regarding the topic on this Forum. They all seem to be linking to another thread explaining this. That thread seems to be no longer available (https://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=142928).
How would I go about checking for MetaField link/links to MetaClass/MetaClassses programmatically, and then delete the link, so that above code would work?
