Unauthorized (401) after commerce update
I have updated commerce packages to 13.25.0 and after trying to launch the site I see the following exception on any page:
The remote server returned an error: (401) Unauthorized.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Net.WebException: The remote server returned an error: (401) Unauthorized.
Source Error:
[No relevant source lines]
Source File: c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\d422b734\41cf754\App_global.asax.de7gtpr-.0.cs    Line: 0
Stack Trace:
[WebException: The remote server returned an error: (401) Unauthorized.]
   System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult) +819
   System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) +47
   System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() +32
   System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) +62
   Microsoft.ServiceBus.Messaging.<OnRunAsync>d__5.MoveNext() +2441
   Microsoft.ServiceBus.Messaging.<RunAsync>d__34.MoveNext() +1478
[UnauthorizedAccessException: The remote server returned an error: (401) Unauthorized. InvalidSignature: The token has an invalid signature. TrackingId:08857315-18e9-4ce0-8eab-d09641179155_G1, SystemTracker:myservicebus.servicebus.windows.net:MySiteEvents, Timestamp:2020-10-24T22:53:23]
   Microsoft.ServiceBus.Messaging.<RunAsync>d__34.MoveNext() +2922
   Microsoft.ServiceBus.<RunAsync>d__8.MoveNext() +450
   Microsoft.ServiceBus.Common.TaskHelpers.CompleteSynchronously(Task`1 task) +109
   EPiServer.Azure.Events.Internal.DefaultServiceBusSetup.CreateTopic(String connectionString, String topicName, Boolean enablePartitioning, Boolean enableExpressQueues, CancellationToken cancellationToken) +281
   EPiServer.Azure.Events.AzureEventProvider.InitializeServiceBusConnection() +1430
   System.Threading.Tasks.Task.Execute() +71
[AggregateException: One or more errors occurred.]
   System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) +4593189
   System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken) +13992992
   System.Threading.Tasks.Task.Wait(TimeSpan timeout) +64
   System.Threading.Tasks.Task`1.InnerInvoke() +40
   System.Threading.Tasks.Task.WaitAll(Task[] tasks, Int32 millisecondsTimeout, CancellationToken cancellationToken) +1264
   EPiServer.Events.EventsInitialization.InitializeEvents(ISiteSecretManager siteSecretManager, IEventSiteRegistry eventSiteRegistry, EventProviderService eventProviderService) +340
   EPiServer.Events.<>c__DisplayClass6_0.<Initialize>b__1(Object sender, EventArgs args) +45
   System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) +0
   System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) +132
   System.Delegate.DynamicInvokeImpl(Object[] args) +160
   EPiServer.Framework.Initialization.InitializationEngine.OnInitComplete() +263
   EPiServer.Framework.Initialization.InitializationEngine.ExecuteTransition(Boolean continueTransitions) +208
   EPiServer.Framework.Initialization.InitializationModule.EngineExecute(HostType hostType, Action`1 engineAction) +423
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +226
   EPiServer.Global..ctor() +42
   Flugger.Web.Global..ctor() +43
   ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\d422b734\41cf754\App_global.asax.de7gtpr-.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +142
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +107
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1476
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +186
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +28
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +80
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +182
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +369
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +532
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +111
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +724
What causes this error and how to mitigate that?
#229835
Oct 24, 2020 23:00
Hi Sergey
It looks like your ServiceBus connnection string (named EPiServerAzureEvents) was affected somehow. It could be because the update or something else.
You may want to verify the connection string against the one from the Azure portal.
#229858
Oct 25, 2020 20:18
