Hi @Viktor Bergman Talani,
This is UI bug and we are fixing it (COM-12226).
Hopefully, it will be released in the next Commerce release (13.28.0)
Thank you for bringing this into our attention
Best regards,
Khiem Nguyen
It seems as if the assets under the Assets pane in Commerce does not sort by SortOrder - or changes the SortOrder for no reason, this makes it very confusing for the editor.
Assets above as uploaded in the UI before publishing the content. So far so good - even after publishing. The assets appear in UI with correct order and in the database they have correct value in SortOrder field.
Now, let's put a new asset in the end of the list:
Hit publish and refresh the UI:
Suddenly 2.0.jpg is second in order?
How come?
The editor needs to manually move 2.0.jpg to the end to acheive the intended order:
Works fine - until she adds 4.1.jpg at the end and publishes:
It's as if new items always get SortOrder 1 - making them appear as second in order.
EPiServer.Commerce.UI 13.24.0
EPiServer.Commerce 13.24.0
