"IExtendedProperties" on payment disappear after saving cart as a purchaseOrder
Hi Forum,
I have a question about "IExtendedProperties". After saving a cart as a purchaseOrder, the values added to "IExtendedProperties" on payments disappear.
Is it a bug or intended behavior. Do I misunderstand something? :)
Screenshot cart order form
https://screenpresso.com/=j1wlf
Screenshot purchaseOrder order form
https://screenpresso.com/=DZgdc
Code
var orderReference = _orderRepository.SaveAsPurchaseOrder(cart);
var purchaseOrder = _orderRepository.Load<IPurchaseOrder>(orderReference.OrderGroupId);
EpiServer.Business.Commerce
12.17.2.3575
BR
Lasse
#207684
Edited, Sep 30, 2019 21:01
No, that shouldn't disappear. We are storing Project Name and retrieving that back to show on Order History Block.
OrderName = order.Properties[MetadataPlusFields.ProjectName.Name]?.ToString();
This is propery information
public static readonly MetadataPlusField ProjectName = new MetadataPlusField
    DataType = MetaDataType.ShortString,
    Description = string.Empty,
    FriendlyName = "Project Name",
    IsEncrypted = false,
    IsMultiLanguage = false,
    IsNullable = true,
    IsSearchable = false,
    Length = 512,
    Name = "ProjectName",
    Namespace = OrderContext.Current.OrderGroupMetaClass.Namespace,
#207714
Oct 01, 2019 10:12
Hi Praful :)
Thank you for your reply.
Properties on our order forms and line items are working fine. It is only on our payments that the value disappears when saving a cart as a purchaseOrder!
BR
Lasse
#207721
Oct 01, 2019 10:50
Can you share your code where you are setting those values on the payment?
#207727
Edited, Oct 01, 2019 13:02
Hej Erik :)
Here is a simplified version of the code:
public IPayment CreatePayment(ICart cart, Guid paymentMethodId, decimal amount) {
            var payment = cart.CreatePayment();
            PopulatePayment(payment, paymentMethodId, amount);
            return payment;
private void PopulatePayment(IPayment payment, Guid paymentMethodId, decimal amount) {
            var row = _paymentService.GetPaymentMethodRow(paymentMethodId);
            payment.Amount = amount;
            payment.PaymentMethodId = paymentMethodId;
            payment.PaymentMethodName = row?.Name;
            payment.Status = PaymentStatus.Pending.ToString();
            payment.TransactionType = TransactionType.Authorization.ToString();
var orderForm = cart.GetFirstForm();
var voucherPayment = CreatePayment(cart, voucherPaymentMethodId, voucherAmountTobeDeducted);
voucherPayment.Properties[Metadata.Payment.VoucherCode] = response.Code;
voucherPayment.Properties[Metadata.Payment.VoucherAvailableAmount] = response.Amount;
orderForm.Payments.Add(voucherPayment);
_orderRepository.Save(cart) // IOrderRepository
And this is how I experience it when I debug:
        public IPurchaseOrder PlaceOrder(ICart cart)
				// Below is what I see when I debug (Can also be seen on the screenshots I have linked to)
				var cartForm = cart.GetFirstForm(); // Debug shows: Payment in cartForm got properties
				var orderForm = purchaseOrder.GetFirstForm(); // Debug shows: Payment in orderForm got no properites
Br
Lasse
#207734
Oct 01, 2019 14:47
Can you try to remove the IPayment and just use GiftCardPayment directly?
public GiftCardPayment CreateVoucherPayment(ICart cart, Guid paymentMethodId, decimal amount, string voucherCode, decimal voucherAmount) {
            var payment = new GiftCardPayment{
                Amount = amount;
                TransactionType = TransactionType.Authorization.ToString()};
            payment.Properties[Metadata.Payment.VoucherCode] = voucherCode;
            payment.Properties[Metadata.Payment.VoucherAvailableAmount] = voucherAmount;
            return payment;
var voucherPayment = CreateVoucherPayment(cart, voucherPaymentMethodId, voucherAmountTobeDeducted, response.Code, response.Amount);
(Disclaimer: free hand code so might not even be formatted correctly)
#207741
Oct 01, 2019 15:16
Did  you add equivalent metafields to your payment?
#207744
Oct 01, 2019 15:33
Hi Quan,
Dooh :/
It helped adding a equivalent metafield to payment?
Thanks a lot to all of you for spending time looking into my issue. It is much appreciated.
Thanks! :)
#207777
Oct 02, 2019 20:13
