In our project we have a class SimpleAddressRouteHandler which overrides SeoUriRouter to set custom market and language.
But after upgrading to Commerce v13, SeoUriRouter has become obsolete. What is the recommended way to replace SeoUriRouter? I can't find any information about it.
Thanks in advance!
Bart
[ServiceConfiguration(ServiceType = typeof(ISimpleAddressRouteHandler), Lifecycle = ServiceInstanceScope.Singleton)]
public class SimpleAddressRouteHandler : SeoUriRouter
[NonSerialized]
private static readonly ILogger _log = LogManager.GetLogger(typeof(SimpleAddressRouteHandler));
private readonly IMarketService _marketService;
private readonly ICurrentMarket _currentMarket;
public SimpleAddressRouteHandler(PartialRouteHandler partialRouteHandler, IContentLoader contentLoader, ReferenceConverter referenceConverter, IContentVersionRepository contentVersionRepository, ICatalogSystem catalogSystem, IMarketService marketService, ICurrentMarket currentMarket)
: base(partialRouteHandler, contentLoader, referenceConverter, contentVersionRepository, catalogSystem)
_marketService = marketService;
_currentMarket = currentMarket;
/// <summary>
/// Tries to handle a segment value as a simple address.
/// </summary>
/// <param name="urlSegment">The simple address</param>
/// <param name="routeRoot">The route root</param>
/// <param name="segmentContext">The segment context</param>
/// <returns><c><see cref="T:EPiServer.Web.Routing.Segments.SimpleAddressRouteValues" /></c> if <paramref name="urlSegment" /> was handled, otherwise <c>null</c></returns>
public override SimpleAddressRouteValues GetRouteValues(string urlSegment, ContentReference routeRoot, SegmentContext segmentContext)
SimpleAddressRouteHandler._log.DebugBeginMethod("GetRouteValues", new object[]
urlSegment,
routeRoot,
segmentContext
//strip software part from the url again
if (urlSegment.StartsWith("software/", StringComparison.InvariantCultureIgnoreCase))
urlSegment = urlSegment.Substring("software/".Length);
if (urlSegment.StartsWith("trainingen/", StringComparison.InvariantCultureIgnoreCase))
urlSegment = urlSegment.Substring("trainingen/".Length);
ProcessLanguageAndMarketSegment(ref urlSegment, segmentContext);
if (urlSegment == null) return null;
return base.GetRouteValues(urlSegment, routeRoot, segmentContext);
public void ProcessLanguageAndMarketSegment(ref string urlSegment, SegmentContext segmentContext)
//Check LanguageMarket segment
if (urlSegment.Contains("/"))
var firstSegment = urlSegment.Split('/')[0]; //First index shouldbe our languageAndMarketSegment
//Our segment is always {TwoLetterIsoCode}-{MarketCode}, therefor segment[2] should always be "-"
if (firstSegment.Length >= 3 && firstSegment[2] == '-')
var segmentParts = firstSegment.Split('-');
//is the last part a valid marketCode
var languagePart = segmentParts[0];
var marketPart = segmentParts[1];
var validMarket = MarketConstants.UrlToMarketMappings.ContainsKey(marketPart);
if (validMarket)
//Set market
var marketCode = MarketConstants.UrlToMarketMappings[marketPart];
var marketId = new MarketId(marketCode);
_currentMarket.SetCurrentMarket(marketId);
//Set language
var market = _marketService.GetMarket(marketId);
var language = market.Languages.FirstOrDefault(x => x.TwoLetterISOLanguageName == languagePart);
if (language == null)
urlSegment = null;
return;
segmentContext.Language = language.ToString();
//Finally strip language and market segment from url
urlSegment = urlSegment.Substring(urlSegment.IndexOf('/') + 1);
error This topic was created over six months ago and has been resolved. If you have a similar question, please create a new topic and refer to this one.
Thanks in advance!
Bart
