Can you not just provide a value for this? Where you create a new relation:
if (relation == null)
relation = relationDto.NodeEntryRelation.NewNodeEntryRelationRow();
relation.CatalogId = catalogId;
relation.CatalogNodeId = nodeId;
relation.CatalogEntryId = entryId;
IsPrimary was released in Commerce 11.2 - https://world.episerver.com/documentation/Release-Notes/?versionFilter=11.2.0&packageFilter=EPiServer.Commerce&typeFilter=All&packageGroup=Commerce
Paul
Hi Paul,
have not been working with ECF.
Took me some time to figure it out.
https://marisks.net/2017/09/19/new-relation-apis-in-commerce-11/
I think you are correct. I will post an update as soon as i run the job again.
Unforunatly, do not have any small xml from client only a full export. Will take some time to import.
Thank you for taking the time to answer.
I am doing a migration job. I have an xml with data and i am importing it to Catalog.
On some items i get following error:
Any idea to why?
2019-07-04T04:54:58,Error,ktms03mstrqx112prep,ab7fea,636978128988831035,0,8452,203,"KTM.Integrations.PIM.EPi.ScheduledJobs.PimXmlAzureImportJobMaster : Column 'IsPrimary' does not allow nulls.
System.Data.NoNullAllowedException: Column 'IsPrimary' does not allow nulls.
at System.Data.DataColumn.CheckNullable(DataRow row)
at System.Data.DataTable.RaiseRowChanging(DataRowChangeEventArgs args, DataRow eRow, DataRowAction eAction, Boolean fireEvent)
at System.Data.DataTable.SetNewRecordWorker(DataRow row, Int32 proposedRecord, DataRowAction action, Boolean isInMerge, Boolean suppressEnsurePropertyChanged, Int32 position, Boolean fireEvent, Exception& deferredException)
at System.Data.DataTable.InsertRow(DataRow row, Int64 proposedID, Int32 pos, Boolean fireEvent)
at KTM.Integrations.PIM.EPi.Data.Parsers.CommerceParserBase.CreateUpdateRelation(Int32 catalogId, Int32 nodeId, Int32 entryId, Int32 sortOrder)
at KTM.Integrations.PIM.EPi.Data.Parsers.StructureParser.ParseProduct(String code, String parent, CatalogType type, TextElementCollectionDescriptor texts)
at KTM.Integrations.PIM.EPi.Data.Parsers.StructureParser.Parse()
at KTM.Integrations.PIM.EPi.Data.Parsers.DataParser.TryRun(Action action, Action`1 errorAction)",80000149-0002-fe00-b63f-84710c7967bb
****** CODE *****
protected CatalogRelationDto.NodeEntryRelationRow CreateUpdateRelation(int catalogId, int nodeId, int entryId, int sortOrder)
var relationDto = GetRelationDto(catalogId, nodeId, entryId);
CatalogRelationDto.NodeEntryRelationRow relation = null;
foreach (var entryRelation in relationDto.NodeEntryRelation.ToList<CatalogRelationDto.NodeEntryRelationRow>())
if (entryRelation.CatalogEntryId.Equals(entryId) &&
entryRelation.CatalogNodeId.Equals(nodeId))
relation = entryRelation;
continue;
relationDto.NodeEntryRelation.RemoveNodeEntryRelationRow(entryRelation);
relation.SortOrder = sortOrder;
if (relation.RowState.Equals(DataRowState.Detached))
relationDto.NodeEntryRelation.AddNodeEntryRelationRow(relation);
else
relation.AcceptChanges();
if (relationDto.HasChanges())
_catalogSystem.SaveCatalogRelationDto(relationDto);
return relation;
