Expired Carts not Expiring
Hey,
I have a lot of carts with a null for meta.modified.  This means the Episerver expiry script will not expire those baskets as it says
Meta.Modified <  GETDATE()
am I missing something or is there a bug in the expiry script?  Here is the sql I ran to see the missed baskets
select count(*) from ordergroup left outer join OrderGroup_ShoppingCart on ([OrderGroup_ShoppingCart].ObjectId=OrderGroup.OrderGroupId) where modified is null
#205461
Jul 11, 2019 13:10
That is strange, as Modified is always updated to the DateTime.UtcNow when you save the cart via AcceptChanges(). How you ended there, I am not quite sure
#205463
Jul 11, 2019 16:38
Thanks, so I should be able to remove them?
#205464
Edited, Jul 11, 2019 17:17
Technically you can try to update modified with created value (which is mandatory) then you can remove them by the scheduled job
#205465
Jul 11, 2019 18:56
Thanks I will remove them then.
#205883
Jul 26, 2019 9:51
