Limit the selection option of ISelectionFactory checkboxes
I have ISelectionFactory which provides collection of ProductNode and it gives me checkboxes of nodes in admin mode. User can select multiploe options over there. But I want to allow only 2.
#202095
Mar 14, 2019 3:12
I would suggest creating a ValidationAttribute for SelectionFactories which will allow you to specifiy the maximum number of elements you want to permit to be selected.
Example Validation Attribute:
    [AttributeUsage(AttributeTargets.Property)]
    public class MaxSelectFactoryItemsAttribute : ValidationAttribute
        private int _max;
        public MaxSelectFactoryItemsAttribute(int max)
            _max = max;
        public override bool IsValid(object value)
            string error = $"restricted to {_max} items!";
            ICollection collection;
            if (value is string)
                collection = ((string)value).Split(',') as ICollection;
            else
                collection = value as ICollection;
            if (collection?.Count > _max)
                ErrorMessage = error;
                return false;
            return true;
        protected override ValidationResult IsValid(object value, ValidationContext validationContext)
            var result = base.IsValid(value, validationContext);
            if (!string.IsNullOrWhiteSpace(result?.ErrorMessage))
                result.ErrorMessage = $"{validationContext.DisplayName} {ErrorMessage}";
            return result;
Example of using the attribute when declaring an element with a SelectionFactory:
        [Display(GroupName = SystemTabNames.Content)]
        [SelectManyExtended(SelectionFactoryType = typeof(ArticleTagSelectionFactory))]
        [MaxSelectFactoryItems(3)]
        public virtual string ArticleTags { get; set; }
Just amend the ValidationAttribute accordingly to handle a collection of product nodes.
#202097
Mar 14, 2019 8:51
Thanks, it works .
#202135
Mar 15, 2019 3:37
