Error message when creating discount
When creating a discount in episerver back office I recieve the following error: Content with id '11663 is of type 'Castle.Proxies.SalesCampaignProxy' which does not inherit required type 'EPiServer.Commerce.Catalog.ContentTypes.CatalogContentBase
The discount is anyway created and works as expected. When I decompile SalesCampaign I can se that it inherits from BasicContent.
Has someone encountered this error before?
Thanks in advance.
#201253
Feb 11, 2019 14:24
Did you use the Marketing UI to create the promotion? or did you use code? Which promotion type did you create?
#201254
Feb 11, 2019 14:40
Also, which Commerce version are you using?
#201266
Feb 11, 2019 18:21
