I think you can use only the registered type and it might not be possible to update the lenght.
Here you can see meta field type meta information
Mediachase.BusinessFoundation.Data.Meta.Management.MetaFieldType
What if you manually update in DB? Is that working?
The "correct" attribute name is McDataTypeAttribute.StringMaxLength, however I think that can only be applied when you create a new metafield. Once you created the field you can't just change the length of the column
I need to change the max length for a field in Contact. The field is a string...
I tested this.
But didnt work. Checked the field in DB in table cls_Contact and the length is the same as before.
Do I must to change it manually?
