Unable to reorganise assets in Catalog UI
Once assets have been added to a variation through Catalog UI, it seems to be impossible to change their sort order. I've tested this in Chrome 67 and Firefox 60, and I hae been able to reproduce this in the latest version of Quicksilver (12.5.0)..
Steps to reproduce:
  1. Go to Catalog UI and open a variation
  2. Add a couple of assets (such as packshots) to the variation and publish it
  3. Publish the variation
  4. Go back to the assets and try to reorder them (either through drag-and-drop or by using the context menu > Move Up / Move Down)
  5. Republish the variation
Expected result: the new sort order is respected
Actual result: the changes are discarded and the order is changed back to what it was
#195615
Aug 01, 2018 15:53
Hi, which version are you using. It sounds like this issue was fixed in Commerce 12.3 IIRC
#195618
Aug 01, 2018 17:26
Hi Quan Mai,
I'm using EPiServer Commerce v12.5 and CMS v11.9.2. I've also tried it in Quicksilver using a clone made today - so Commerce 12.5, CMS 11.9.1.
#195619
Aug 01, 2018 18:06
I can confirm this is a bug, and I might have something to do with it. I will file a bug and we will look into it.
#195625
Aug 02, 2018 6:30
This was fixed and will be released in Commerce 12.6
#195843
Aug 09, 2018 10:22
Great, thanks for the swift response!
#195855
Aug 09, 2018 13:24
