You should implement IShippingPlugin instead of IShippingGateway (you can implement both, however)
We're already using IShippingGateway.
var shippingGateway = (IShippingGateway)Activator.CreateInstance(type, ServiceLocator.Current.GetInstance<ICurrentMarket>().GetCurrentMarket());
shippingGateway.GetRate() expects Guid methodId, Shipment shipment, ref string message
We're on Commerce 11.8.3 if that makes a difference. Documentation says this is valid for 10 and up.
If you want to use the abstraction, you should implement IShippingPlugin which use IShipment instead
I'm currently in a project where we try to switch over to using ICart. I'm stuck trying to get the shipping rates from a shipping gateway.
Getting the rates from a shipping gateway requires a Shipment object, not IShipment as ICart use. But according to docs it should be a list of LineItem (not ILineItem) as input.
Any suggestions?
