We used the ValidateLineItemsActivity to change a certain validation:
var isPromoItem = lineItem["IsPromoItem"] != null;
//check if the entry is not available
if ((!isPromoItem && !entryRow.IsActive) || requestDate < minAvailableDate || requestDate > entryRow.EndDate)
AddWarningSafe(Warnings, "LineItemRemoved-" + lineItem.LineItemId.ToString(),
String.Format("Item \"{0}\" has been removed from the cart because it is not available.",
lineItem.DisplayName));
lineItemsToRemoved.Add(lineItem);
continue;
If I'm not mistaken, I should now use the IsValidCatalog in my custom DefaultLineValidator to add my validation:
protected override bool IsValidCatalog(EntryContentBase entry, DateTime requestDate)();
CatalogDto.CatalogRow catalogRow = this._catalogSystem.GetCatalogDto(entry.CatalogId).Catalog.FirstOrDefault
if (catalogRow != null && catalogRow.IsActive && requestDate >= catalogRow.StartDate)
return requestDate <= catalogrow.enddate>
return false;
My problem is that our custom property was on the lineitem and now I only have a EntryContentBase. Is there a way to access ou property from this function?
If not, how should I fix this?
