referenceConverter.GetContentLink returns empty contentreference
var contentLink = _referenceConverter.GetContentLink(code);
if (ContentReference.IsNullOrEmpty(contentLink))
    return null;
When I try to find a product via code the contentreference becomes empty.
This works on several other products and I can not see any difference between the products that work and those whom doesn't work.
Any ideas how to debug this further?
#194592
Jun 26, 2018 10:21
Can you check if a product with that code actually exists?
#194603
Jun 26, 2018 11:34
Yes it does, if only it was that easy.
#194604
Jun 26, 2018 12:28
Did you make sure the code you passed matches exactly with the code in database? Did you try the other overload which takes the catalog content type?
#194606
Jun 26, 2018 13:17
Exactly as in database, yes. Overload with catalog content type, yes - same result.
As written before.
#194607
Jun 26, 2018 13:24
Then you should probably contact developer support service for further assistance :)
#194609
Jun 26, 2018 14:35
