Hey Scott
If I understand correctly you want to render the sitemap as content on a page?
David
Yes a full sitemap of content and commerce with the correct structure from the commerce routing as a page. We'll turn it in to some sort of collapsable accordion sort of thing
Just an idea but couldn't you just parse/use the generated sitemap xml file?
You're the man for us today :-) Yeah I could, it wouldn't probably take too long to write something I was just hoping there might be something I'd missed available that did it already. Thanks
We are using the Geta sitemaps plugin which is great for the XML sitemaps but we want to render a sitemap on a page with all the CMS and routed Commerce URLs. I can't see any easy way of using the code when reflecting on the Geta plugin, does anyone have any examples of code that will get all these cms/commerce pages as an example?
