That is strange. Assuming you are talking about BuyQuantityGetSelectedItemsDiscount - are you sure your cart is not being applied some other promotions?
No, I mean "Spend for Discounted Selection
Spend amount to receive a discount on selected items."
I assume that it is "SpendAmountGetItemDiscount" in the code.
I am sure that there is no other discount is created.
I asked our QAs to replicate the behavior, however can you try it on Quicksilver 12.2 to see if you can still reproduce it?
I used to use old version of Quicksilver, it will take sometime to setup latest Quicksilver.
Our QAs confirmed that they can reproduce the behavior. We will file a bug for this and will look into it.
Hello
Another one question about new marketing system.
We use EPiServer Commerce v 11.2.6.0.
The configuration is:
I add an item from level 1 category and open shopping cart. Discount has applied to item.
After that I add an item from level 2 category and open shopping cart. Discount has applied only to item from level 1 category. It is expected result.
But if after that I change qty of item from level 2 category in shopping cart, totals will be recalculated and discount will be applied to both items (level 1 and level2). It is unexpected cause "Include subcategories" option is turned off.
Could you please check this configuration or give any advice to find out root cause of the issue.
