Here is the entire serviceModel section of web.config
<system.serviceModel>
<serviceHostingEnvironment aspNetCompatibilityEnabled="true" multipleSiteBindingsEnabled="true" />
<extensions>
<bindingElementExtensions>
<add name="udpTransportCustom" type="Microsoft.ServiceModel.Samples.UdpTransportElement, EPiServer.Framework.AspNet" />
</bindingElementExtensions>
</extensions>
<services>
<service name="EPiServer.Business.Commerce.Services.ProductRating" behaviorConfiguration="CommerceSiteBehavior">
<endpoint address="" binding="webHttpBinding" contract="EPiServer.Business.Commerce.Services.IProductRating" behaviorConfiguration="CommerceSiteBehavior" />
</service>
<service name="EPiServer.Business.Commerce.Services.ProductComment" behaviorConfiguration="CommerceSiteBehavior">
<endpoint address="" binding="webHttpBinding" contract="EPiServer.Business.Commerce.Services.IProductComment" behaviorConfiguration="CommerceSiteBehavior" />
</service>
<service name="EPiServer.Events.Remote.EventReplication" behaviorConfiguration="DebugServiceBehaviour">
<endpoint name="RemoteEventServiceEndPoint" contract="EPiServer.Events.ServiceModel.IEventReplication" binding="customBinding" bindingConfiguration="RemoteEventsBinding" address="soap.udp://<SOME_IP_ADDRESS>/RemoteEventService" />
</service>
</services>
<behaviors>
<serviceBehaviors>
<behavior name="DebugServiceBehaviour">
<serviceDebug includeExceptionDetailInFaults="true" />
</behavior>
<behavior name="CommerceSiteBehavior">
<serviceMetadata httpGetEnabled="true" />
<!--TODO: the option should be only in test environment true in the production should be false-->
</behavior>
</serviceBehaviors>
<endpointBehaviors>
<webHttp />
</behavior>
</endpointBehaviors>
</behaviors>
<bindings>
<webHttpBinding>
<binding name="IndexingServiceCustomBinding" maxBufferPoolSize="1073741824" maxReceivedMessageSize="2147483647" maxBufferSize="2147483647">
<readerQuotas maxStringContentLength="10000000" />
</binding>
</webHttpBinding>
</bindings>
<client>
<endpoint name="RemoteEventServiceClientEndPoint" address="soap.udp://<SOME_IP_ADDRESS>/RemoteEventService" binding="customBinding" bindingConfiguration="RemoteEventsBinding" contract="EPiServer.Events.ServiceModel.IEventReplication" />
</client>
</system.serviceModel>
This is the setting that works
<extensions>
</extensions>
<services>
<endpoint name="RemoteEventServiceEndPoint" contract="EPiServer.Events.ServiceModel.IEventReplication" binding="customBinding" bindingConfiguration="RemoteEventsBinding" address="soap.udp://239.255.255.19:5000/RemoteEventService" />
</service>
</services>
<client>
<endpoint name="RemoteEventServiceClientEndPoint" address="soap.udp://239.255.255.19:5000/RemoteEventService" binding="customBinding" bindingConfiguration="RemoteEventsBinding" contract="EPiServer.Events.ServiceModel.IEventReplication" />
</client>
<behaviors>
<serviceBehaviors>
<!--TODO: This option should only be enabled in test environments. It should be disabled for any site in production.-->
</behavior>
</behavior>
</serviceBehaviors>
<endpointBehaviors>
<webHttp />
</behavior>
</behaviors>
<bindings>
<customBinding>
<binding name="RemoteEventsBinding">
<binaryMessageEncoding />
<udpTransportCustom multicast="True" />
</binding>
</customBinding>
</bindings>
<!-- Enable remote service -->
Think you might be missing this
<bindings> <customBinding> <binding name="RemoteEventsBinding"> <binaryMessageEncoding /> <udpTransportCustom multicast="True" /> </binding> </customBinding> </bindings>
Quan, I need to buy you a case of beer my man, the configuration you posted solved my issue. I've now gotten to the migration steps... hallelujah
I'm getting the following error when running our front end site after upgrading CMS and Commerce to 11.7 and 12.2 respectively.
The binding at system.serviceModel/bindings/customBinding does not have a configured binding named 'RemoteEventsBinding'. This is an invalid value for bindingConfiguration.
