Deleted variant still in cart? [12.8]
If I place a variant in my shopping cart and the delete the variant from the catalog the variant is still loaded into the cart.  Even if I restart everything the variant is still loaded.
This code gives me the deleted variant:
var lineItems = cart.GetAllLineItems();
var variantReferences = _referenceConverter.GetContentLinks(lineItems.Select(l => l.Code))
                .Select(c => c.Value).Where(c => !ContentReference.IsNullOrEmpty(c));
var variants = _contentLoader.GetItems(variantReferences,_preferredCulture).OfType().ToList();
These validations are run:
cart.ValidateOrRemoveLineItems((item, issue) => issues.AddValidationIssues(item, issue), _lineItemValidator);
cart.UpdateInventoryOrRemoveLineItems((item, issue) => issues.AddValidationIssues(item, issue), _inventoryProcessor);
cart.ApplyDiscounts(_promotionEngine, new PromotionEngineSettings());
cart.UpdateInventoryOrRemoveLineItems((item, issue) => { }, _inventoryProcessor);
I get all information about the variant even though it is deleted, but I can't get an url to the item which I guess is how it is supposed to be.
Is this Episerver standard or maybe I'm missing something here?
/Kristoffer
#199317
Nov 22, 2018 15:17
Did you save your cart after running validation? Because
should remove line items with variant deleted, however it does not save the cart
#199326
Nov 22, 2018 15:57
Ok, that might be it! And you only have to save it if there are any validation issues I guess?
#199331
Nov 22, 2018 17:47
That was it! In one place I did a validation without saving the cart, thanks Quan!
#199333
Nov 22, 2018 19:26
