Access to Commerce tab in episerver
Hey,
I would like to create user accounts for the sales group which can have the full access to following view in episerver (Commerce part).
Commerce tab
- Catalog
- Marketing
- Commerce Manger (every view excepts "Administration")
I tried with CommerceAdmins role but it doesn't work if the user is not WebAdmins or Administrators.
Which administer groups shall the sales be member of?
Do I need to create a new role for this scenario? If so, any suggestions?
ChiChing
#199265
Nov 22, 2018 10:07
You would have to create a new group, and assign these permissions to it
Except any permission with ":admin:" part (which corresponding to Administration part in Commerce Manager)
Then create virtual roles and assign it to your new group
For catalog - CatalogManagers
For Marketing - MarketingManagers
#199279
Nov 22, 2018 11:34
Thank you for your quick response Quan!
I have created a group calls "CommerceSales" and edit in the Permission for Functions.
I am not sure if I created virtual role correctly. Would you like to check in the screenshots?
  • created a VirtualRoleInitializer class
  • created a virtual role "CommerceSalesRole
How do I assgin CommerceSalesRole to the new group CommerceSales?
#199296
Nov 22, 2018 13:05
Add these to <episerver.framework>/<virtualRoles>/<providers>
<add name="CatalogManagers" type="EPiServer.Security.MappedRole, EPiServer.Framework" roles="CommerceSales" mode="Any" />
<add name="MarketingManagers" type="EPiServer.Security.MappedRole, EPiServer.Framework" roles="CommerceSales" mode="Any" />
#199298
Nov 22, 2018 13:13
Do you know why the GetDefault is incorrect?
Do I need to add any logic to IsInVirtualRole method?
public override bool IsInVirtualRole(IPrincipal principal, object context)
throw new NotImplementedException();
#199301
Nov 22, 2018 13:46
I just want to to add that there is a section in the user documentation that describes how to set up access rights to different views in Commerce. You can find it here, http://webhelp.episerver.com/latest/commerce/access-rights.htm.
Edit: There should be no need for you to create your own virtual role type. The only thing that matters is that the user is part of a role with the names that you can see in documentation above. If that is a role provided by our virtual role type mapped role, or just a role from the AD, or anywhere else, doesn't matter. The system only does an is in role check for any role by that name.
Regards
Per Gunsarfs
#199302
Edited, Nov 22, 2018 13:52
No, you don't have to, just add the virtual roles as I suggested.
If you want to create the virtual roles progammatically, you are doing it wrong. You would have to use context.Locate.Advanced.GetInstance<IVirtualRoleRepository>() to get an instance of the virtual role repository, and continue from there.
#199305
Nov 22, 2018 14:33
Yes. I have added the virtual  roles to the web.config.
Unfortunately I still couldn't log in with the user account that I created.
Do I miss anything else?
BR,
ChiChing
#199312
Nov 22, 2018 14:55
Did you mean you can't login to CM? Did you assign core:mng:login permission to that account?
#199316
Nov 22, 2018 15:17
I mean I couldn't log in to ../Util/login.aspx
Yes, I assigned core:mng:login permission to CommerceSales.
#199318
Nov 22, 2018 15:28
By default that path is only allowed to specific roles WebEditors, WebAdmins, Administrators. Your account was logged in successfully, but was denied access so the framework asks for login a gain.
You would have to add the roles here
<location path="episerver">
<system.web>
<httpRuntime maxRequestLength="1000000" requestValidationMode="2.0" />
<pages enableEventValidation="true" enableViewState="true" enableSessionState="true" enableViewStateMac="true">
<controls>
<add tagPrefix="EPiServerUI" namespace="EPiServer.UI.WebControls" assembly="EPiServer.UI" />
<add tagPrefix="EPiServerScript" namespace="EPiServer.ClientScript.WebControls" assembly="EPiServer.Cms.AspNet" />
<add tagPrefix="EPiServerScript" namespace="EPiServer.UI.ClientScript.WebControls" assembly="EPiServer.UI" />
</controls>
</pages>
<globalization requestEncoding="utf-8" responseEncoding="utf-8" />
<authorization>
<allow roles="WebEditors, WebAdmins, Administrators" />
<deny users="*" />
</authorization>
#199322
Nov 22, 2018 15:42
Thank you so much Quan! It works :)
#199364
Nov 23, 2018 12:59
