It looks like the property is shared between multiple content types. Make sure that you remove all [CultureSpecific] attribute on that property on all classes
Yes, is true. In Product has also a imageMedium. It seems both Product and Category share the imageMedium metadata field.
I will create a new property without CultureSpecific instead.
Thanks Quan!
Hi guys,
I have created a property "ImageMedium" in my Catgory,
[Searchable]
[Tokenize]
[IncludeInDefaultSearch]
[Display(Order = 2000)]
[CultureSpecific]
public virtual Url ImageMedium { get; set; }
and I would like to remove the [CultureSpecific]. After i removed the it, the site came the following error.
The property 'ImageMedium' was found on multiple content types, but with different CultureSpecific attribute values.
I tried to go into Administration > Meta Fields and uncheck the "Supports Multiple Languages". It seems nothing happened.
Any tips?
ChiChing
