Invalid object name 'MetaClass'.
I get an error after uploading my website to DXC.
If I run it locally (but connect to the same database) It works fine.
Error message (both CMS and Commerce have the same exception)
Exception Details: System.Data.SqlClient.SqlException: Invalid object name 'MetaClass'.
Source Error:
[No relevant source lines]
Source File: d:\local\Temporary ASP.NET Files\root\d0e2cce6\afd7f897\App_global.asax.0.cs    Line: 0
Stack Trace:
[SqlException (0x80131904): Invalid object name 'MetaClass'.]
   System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction) +274
   System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) +720
   System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) +4284
   System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() +108
   System.Data.SqlClient.SqlDataReader.get_MetaData() +103
   System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption) +601
   System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest) +3152
   System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry) +717
   System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +117
   System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) +1250
   System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) +193
   System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior) +403
   System.Data.Common.DbDataAdapter.Fill(DataTable dataTable) +150
   Mediachase.Data.Provider.<>c__DisplayClass16_2.b__0() +122
   EPiServer.Data.Providers.SqlTransientErrorsRetryPolicy.Execute(Func`1 method) +665
   Mediachase.Data.Provider.SqlDataProvider.LoadTable(DataCommand command) +511
   Mediachase.MetaDataPlus.Common.DBHelper.ExecuteDataTable(String connectionString, CommandType commandType, String commandText, Int32 commandTimeout, DataParameter[] commandParameters) +197
   Mediachase.MetaDataPlus.Configurator.StoredProcedure.ExecuteDataTable(MetaDataContext context) +54
   Mediachase.MetaDataPlus.Configurator.MetaClass.LoadFromDb(MetaDataContext context, Func`2 dbLoader) +41
   EPiServer.Framework.Cache.ObjectInstanceCacheExtensions.ReadThroughWithWait(IObjectInstanceCache cache, String cacheKey, Func`1 readValue, Func`2 evictionPolicy) +1019
   Mediachase.MetaDataPlus.Configurator.MetaClass.ReadThroughCache(String cacheKey, MetaDataContext context, Func`2 dbLoader, Func`2 additionalCacheKeyCreator) +245
   Mediachase.MetaDataPlus.Configurator.MetaInstaller.LoadMetaClassVersion10(MetaDataContext context, XmlNode xmlMetaClass, MetaClass parent) +139
   Mediachase.MetaDataPlus.Configurator.MetaInstaller.RestoreFromVersion10(MetaDataContext context, XmlNode root) +566
   Mediachase.MetaDataPlus.Configurator.MetaInstaller.Restore(MetaDataContext context, XmlNode root) +175
   Mediachase.Commerce.Catalog.CatalogConfiguration.ConfigureMetaData() +118
   EPiServer.Framework.Initialization.Internal.ModuleNode.Execute(Action a, String key) +55
   EPiServer.Framework.Initialization.Internal.ModuleNode.Initialize(InitializationEngine context) +131
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +248
[InitializationException: Initialize action failed for Initialize on class Mediachase.Commerce.Initialization.CatalogInitialization, Mediachase.Commerce, Version=11.6.1.0, Culture=neutral, PublicKeyToken=6e58b501b34abce3]
   EPiServer.Framework.Initialization.InitializationEngine.InitializeModules() +774
   EPiServer.Framework.Initialization.InitializationEngine.ExecuteTransition(Boolean continueTransitions) +203
   EPiServer.Framework.Initialization.InitializationModule.EngineExecute(HostType hostType, Action`1 engineAction) +876
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +167
   EPiServer.Global..ctor() +83
   PartenaCMS.EPiServerApplication..ctor() +37
   ASP.global_asax..ctor() in d:\local\Temporary ASP.NET Files\root\d0e2cce6\afd7f897\App_global.asax.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +197
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +114
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1514
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +300
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +27
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +80
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +225
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +318
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +444
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +113
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +604
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.7.2558.0
Any thoughts?
Thanks in advance!
Brecht Vanneste
#186879
Jan 08, 2018 11:43
Which versions are you using?
And did you make sure the connection strings are correct? it seems to me that the EcfSqlConnection is pointing to a database which has no "MetaClass" table.
#186882
Jan 08, 2018 12:01
Oh sorry I forgot:
CMS:
EPiServer.CMS.Core 11.3.1
EpiServer.Azure 9.4.1
EPiServer.Commerce.Core 11.6.1
EPiServer.Commerce.Azure 11.6.1
Commerce
EPiServer.CommerceManager 11.6.1
EPiServer.CommerceManager.Azure 11.6.1
I'm using the same connection string as I do local.
In the commerce db there is a table "MetaClass"
Thank you for the fast response.
#186889
Jan 08, 2018 12:51
Hmm - strange. Does that MetaClass table belong to "dbo" schema?
#186890
Jan 08, 2018 12:54
Yes it does.
Strange indeed :)
#186894
Jan 08, 2018 13:20
Can you catch the sql call with sql profiler?
Could it be a security issue?
Does the database allow traffic from all ip-adresses?
#186918
Jan 08, 2018 17:06
I cleared the folder trough ftp, after that everything worked as normal.
Thank you for your time!
#187376
Jan 22, 2018 9:51
