RecordPromotionUsageActivity is obsolete
We just upgraded to Commerce 11 and we have our own checkout workflow. When I compile in release build I get this error:
"RecordPromotionUsageActivity is obsolete. Use promotion system in EPiServer.Commerce.Marketing instead. Will be removed in a future major release, but not earlier than August 2018."
We still use workflows, do we need do stop using workflows to get rid of this message?
[ActivityFlowConfiguration(Name = "DolCartCheckout")]
    public class DolCartCheckoutActivityFlow : ActivityFlow
        public override ActivityFlowRunner Configure(ActivityFlowRunner activityFlow)
            return
                activityFlow
                    .If(ShouldProcessPayment)
                        .Do()
                    .EndIf()
                    .Do()
                    .Do()
                    .Do()
                    .Do();
Thanks!
/Kristoffer
#181960
Edited, Sep 06, 2017 10:39
If you are using the new promotion system (which you should), then you can remove RecordPromotionUsageActivity from your ActivityFlow.
If you are not, we recommend to move to the new promotion system as soon as possible.
#181962
Sep 06, 2017 11:57
Ah, perfect!
Yes, we are using the new one but still with workflows, but it is ok to remove so I will do that.
Thanks Quan!
/Kristoffer
#181963
Sep 06, 2017 11:58
