Category Publish Issue
Hey!
I'm running into an issue where when I publish a top level category, it updates the UriSegment table for each language, to have different random encoded values on the end.
#182026
Edited, Sep 07, 2017 23:16
We are currently in the process of QAing an upgrade of commerce from 9.11 to 10.10.1. Any ideas as to what might cause something like this?
#182027
Sep 07, 2017 23:17
Edit: This was fixed in Commerce 11.1.1 (see Quan's post below)
I recall something like this (unsure if it was CMS hierarchy or commerce, but..), do you have the "Optics" somewhere else in the commerce hierarchy? Even though it might be at another level they perhaps are globally unique.
#182034
Edited, Sep 08, 2017 8:23
There was a bug that requires the UriSegment for node to be unique globally, therefore when you save a node and the system finds that you have another UriSegment with same value (even if that is in another category and should not conflict with this one), it will try to add some random values to make UriSegment unique. That bug (COM-4964) was fixed in Commerce 11.1.1
#182046
Edited, Sep 08, 2017 9:58
Hey Quan,
Thanks for answering this question. I'll update our project to 11.1.1 and see what happens.
We've also seen extremly poor performance when publishing. Sometimes it take up to a minute to publish. Could this be related to the same bug?
-Paul
#182065
Sep 08, 2017 15:18
Also, I read the bug notes on this. This almost makes it sound like the bug here is that the catalog UI allows you to have non-unique urisegments, not that it appends the alpha codes.
When we do this update, are we still going to be able to have duplicate urisegments?
We need duplicates because we have a /optics/ category, but also a /clearance/optics catagory.
-Paul
#182066
Sep 08, 2017 15:20
I can't say for sure if it relates to that bug - you can always use some profiler (dotTrace, for example) to profile why it is slow and get back to us.
The bug fix actuallys lifts the restriction quite a lot, so yes, you will (be able to) have duplicate urisegments, as long as they are not in the same parent
#182067
Edited, Sep 08, 2017 15:25
ok, sounds good. Thanks!
#182068
Sep 08, 2017 15:26
Upgrading to Commerce 11.1.1 resolved this issue. Thanks!
#182079
Sep 08, 2017 16:47
