Solved by initializing EpiFind as such:
conv.ForInstancesOf<FashionProduc>()
.IncludeField(x => x.ThumbnailUrl(), (x, v) => x.SetThumbnailUrl(v));
Hello
I am trying to change the search index of the "EPiServer.Reference.Commerce.Site"-project in Quicksilver to target Episerver.Find.
Usings:
Latest quicksilver version: https://github.com/episerver/Quicksilver
Commerce v.11.0
Episerver v.10.10
Episerver.Find v.12.5.2.0
Episerver.Find.Commerce v.10.0 (to fill the Find-index with data from Commerce)
Issue/goal: Getting custom Field from the Index, that is not directly on the model I am searching with, but the value from the custom Field should be set to some property/field on the model.
What I have done:
1) Downloaded and unzipped the QuickSilver application and initialized it, so it ran perfectly with the default search provider and indexer.
2) Installed Episerver.Find and Episerver.Find.Commerce
3) Created a Episerver.Find demo index (https://find.episerver.com/)
4) Added required Find-configurations to the web.config (serviceUrl and defaultIndex)
5) Logged in as admin@example.com > Edit mode > Admin > ran the "EPiServer Find Content Indexing Job
6) Checked the index through the "Find Explorer" (http://localhost:50244/episerver/Find/#overview/explore)
The index looks good. IContent from Commece is within the Find Index, so Episerver.Find.Commerce has done its job.
For instance, a FahsionProduct-object contains these Fields inside the index (they are not properties on the Model itself, nor any inherited property...):
7) Now I thought I would just add a property on the Model I am searching with, and I would get these values from the Find.Index...
The fields/properties are always null, never filled with the value from the Index (same goes for DefaultImageUrl)...
Edit: Not sure if this is related to Commerce or Find, or both... Will create a sample console application with Find only...
Best regards
NJ
