You can go to Commerce Manager, Administration, Catalog System, MetaClass, select your metaclass and unlink the metafield from there
Thanks but how do I get rid of the actual MetaClass? There are no delete buttons anywhere.
This might help you: https://world.episerver.com/blogs/Quan-Mai/Dates/2014/10/Clean-up-catalog-metadata-system/
Ok but the obvious question is, why isn't this built in? Strange that this functionality was omitted from the admin.
Maybe next patch?
Since I am not using webforms (version 10), maybe a better idea would be to create some kind Job out of this but I need to be 100% what SQL to run here.
My problem right now Quan, is that I actually get a YSOD when trying to use a variantfield. This is a real show stopper. I really would like some kind of solution for this.
I could be blind but I don't see any way to remove these. I made some mistakes when designing the class and
for some reason these values won't go away as I recompile. Do I have to manually remove them from the db and if so what is the sql to use?
Thanks in advance.
Version 10
