CheckoutController init exception after adding meta field.
After adding a metafield to the Commerce object Cart Order Class and Purchase Order we no longer can load the CheckoutController without exception:
No parameterless constructor defined for this object.
Exception Details: System.MissingMethodException: No parameterless constructor defined for this object.
Source Error:
Stack Trace:
[MissingMethodException: No parameterless constructor defined for this object.]
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +197
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +114
   System.Activator.CreateInstance(Type type) +11
   System.Web.Mvc.DefaultControllerActivator.Create(RequestContext requestContext, Type controllerType) +72
[InvalidOperationException: An error occurred when trying to create a controller of type 'Designonline.Site.Features.Checkout.Controllers.CheckoutController'. Make sure that the controller has a parameterless public constructor.]
   System.Web.Mvc.DefaultControllerActivator.Create(RequestContext requestContext, Type controllerType) +239
   System.Web.Mvc.DefaultControllerFactory.CreateController(RequestContext requestContext, String controllerName) +103
   System.Web.Mvc.MvcHandler.ProcessRequestInit(HttpContextBase httpContext, IController& controller, IControllerFactory& factory) +293
   System.Web.Mvc.MvcHandler.BeginProcessRequest(HttpContextBase httpContext, AsyncCallback callback, Object state) +104
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +1939
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +2622
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +973
We ha rebuilt and restarted several times without luck, what are we missing?
We are using Commerce 10.7 built on QuickSilver.
Thanks!
/Kristoffer
#180439
Jul 10, 2017 17:12
What is the code (or at least the constructor) of your CheckoutController? Mind sharing it here?
#180440
Jul 10, 2017 17:44
I had nothing to do with it actually. I was another component that was initiated in the constuctor that needed payment settings that not all configurations had. We added a meta field at the at the same time, there for we thought it had to do with that.
/Kristoffer
#180441
Jul 10, 2017 18:04
" I was another component that was initiated in the constuctor that needed payment settings that not all configurations had." => I would suspect this was the problem
#180446
Jul 11, 2017 8:55
