Custom Promotion - how to use a radio button in the UI?
I'm coding some custom promotion types.
I've noticed that some of the built-in promotion types have a radio button in their UI to select between "Percentage Off" / "Amount Off".
I'd like to do something similar - I want to use a radio button to show 1 of 2 properties on my promotion type..
How can I do it?
 - Ken
#179205
Jun 02, 2017 23:01
To customize UI for properties on your promotion type, you can create a BlockData for those properties like that
public class CustomProperties : BlockData
    public Type Property1
    public Type Property2
Then you need register an EditorDescriptor for that block to customize UI in the client side.
[EditorDescriptorRegistration(TargetType = typeof(CustomProperties))]
public class CustomPropertiesEditorDescriptor : EditorDescriptor
    public CustomPropertiesEditorDescriptor()
        ClientEditingClass = "js/editors/CustomPropertiesEditor";
Finally you create a dojo widget to render those properties using radio button as you want.
Hope that helps.
/Tuan
#179423
Edited, Jun 12, 2017 12:19
Is there a good example online showing how I can do this?  ("dojo widget"?)
I'd like to do something similar to how a "MonetaryReward" looks on a promotion.  Ideally I would just look in the code to see how that one works - but I can't seem to locate that source code....
#185055
Nov 08, 2017 22:57
Here is an overral example good for you. https://world.episerver.com/blogs/hakon-nordli/dates/2015/10/learn-how-to-develop-your-own-dojo-widget3/
#185075
Nov 09, 2017 4:39
