Order Address MetaFields Saving Issue
Using EPIServer.Commerce 10.4:
I am trying to save the payment billing address as following:
IOrderAddress address = GetDefaultBillingAddress();
address.Id = Constants.Order.BillingAddressName;
address.Properties["IsValidated"] = true;
address.Properties["UserChoosetoOverrideValidation"] = true;
payment.BillingAddress = address;
ServiceLocator.Current.GetInstance().Save(cart);
All properties are saved properly except the MetaFields. They are all null.
Any thoughts?
Thanks!
#176199
Mar 13, 2017 18:05
I believe this is fixed in 10.4.1 released today.
#176201
Mar 13, 2017 18:40
I still have the same issue after upgrading to 10.4.1
It is really a weird behavior as it works fine for Shipment shipping address but not for Payment billing address and they both have same code (Pasted below).
            if (AddressName == Constants.Order.BillingAddressName)
                var addressMetaFields = new Hashtable(address.Properties);
                foreach (var field in addressMetaFields.Keys)
                    if (addressMetaFields[field] != null)
                        payment.BillingAddress.Properties[field] = addressMetaFields[field];
            else if (AddressName == Constants.Order.ShippingAddressName)
                IOrderAddress address = GetDefaultShippingAddress();
                address.Id = Constants.Order.ShippingAddressName;
                shipment.ShippingAddress = address;
                        shipment.ShippingAddress.Properties[field] = addressMetaFields[field];
            ServiceLocator.Current.GetInstance<IOrderRepository>().Save(cart);
#176203
Mar 13, 2017 20:16
I was wrong, the issue I was thinking about was fixed in 10.4 already, so this is something else. I assume your metaclass really has these fields (with names exactly like you assign, casing and all)?
#176204
Mar 13, 2017 20:39
Correct, they have same name exactly.
All attached to the order group address meta class.
#176205
Mar 13, 2017 20:42
Did this work before on a previous version? (I currently have no idea what is wrong, but first step is to limit the scope)
#176215
Mar 14, 2017 0:28
Before we used the old Cart APIs and we were attaching the billing and shipping addresses to OrderAddresses property in Cart object.
It was working fine and meta fields were populated properly.
This is the first time to test the version 10 upgrade and we just came through this issue.
#176248
Mar 14, 2017 13:36
This will be a bug and we will fix this soon.
#176475
Mar 20, 2017 11:00
Thanks @Son for the update!
#176507
Mar 20, 2017 14:54
I just want to inform that the problem was fixed in 10.4.3
#178290
May 08, 2017 5:56
