That's very strange. CustomerContext.Current is a static property and it should not be different between pages.
What do you have in PrincipalInfo.Current.Principal? If PrincipalInfo.Current.Principal.GetCustomerContact() returns null then it's likely because PrincipalInfo.Current.Principal is null or PrincipalInfo.Current.Principal.Identity is null
Hi Quan,
PrincipalInfo.Current.Principal.Identity Is null.
regards
phani
QuickSilver is using Owin/AspnetIdentity and those properties work perfectly. I suspect it's something in your configuration - so as usual - I would suggest you to contact our developer support service for further assistance
Hi Quan,
I have implmented the AspIdentity provider. However situation is same.
I am facing the issue on webapi calls .
PrincipalInfo.Current.Principal.GetCustomerContact() is always null.
Regards
Venkata Phani kumar R
Can you post your Startup.cs file here, if it does not contain any sensitive information?
This is a less known area and I've never seen this error, so I'm not sure I can spot anything. We should be able to say more if we have the entire solution which can reproduce the problem.
public class Startup
private readonly ILogger _logService = EPiServer.Logging.LogManager.GetLogger(System.Reflection.MethodBase.GetCurrentMethod().DeclaringType);
// For more information on configuring authentication,
// please visit http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-CMS/9/Security/episerver-aspnetidentity/
private readonly IConnectionStringHandler _connectionStringHandler;
public Startup() : this(ServiceLocator.Current.GetInstance<IConnectionStringHandler>())
// Parameterless constructor required by OWIN.
public Startup(IConnectionStringHandler connectionStringHandler)
_connectionStringHandler = connectionStringHandler;
public void Configuration(IAppBuilder app)
// Add CMS integration for ASP.NET Identity
app.AddCmsAspNetIdentity<SiteUser>(new ApplicationOptions
ConnectionStringName = _connectionStringHandler.Commerce.Name
// Use cookie authentication
app.UseCookieAuthentication(new CookieAuthenticationOptions
AuthenticationType = DefaultAuthenticationTypes.ApplicationCookie,
LoginPath = new PathString("/User"),
Provider = new CookieAuthenticationProvider
OnValidateIdentity =
SecurityStampValidator.OnValidateIdentity<ApplicationUserManager<SiteUser>,SiteUser>(
validateInterval: TimeSpan.FromMinutes(30),
regenerateIdentity: (manager, user) => manager.GenerateUserIdentityAsync(user))
app.UseExternalSignInCookie(DefaultAuthenticationTypes.ExternalCookie);
// Enables the application to temporarily store user information when they are verifying the second factor in the two-factor authentication process.
app.UseTwoFactorSignInCookie(DefaultAuthenticationTypes.TwoFactorCookie, TimeSpan.FromMinutes(5));
// Enables the application to remember the second login verification factor such as phone or email.
// Once you check this option, your second step of verification during the login process will be remembered on the device where you logged in from.
// This is similar to the RememberMe option when you log in.
app.UseTwoFactorRememberBrowserCookie(DefaultAuthenticationTypes.TwoFactorRememberBrowserCookie);
Hi All,
I have an issue with CustomerContext.Current . In CMS pages CustomerContext.Current is giving the right detial of the login person. Where as on Commerce pages eg: Product Details pages ,CustomerContext.Current is Null.
PrincipalInfo.Current.Principal.GetCustomerContact() is also null.
if (System.Web.HttpContext.Current.Request.LogonUserIdentity != null &&
System.Web.HttpContext.Current.Request.LogonUserIdentity.IsAuthenticated) is true.
I am using form authentication . Owin Components are instaaled to use the service api features.
Can some one suggest me the instructions to trouble shoot this issue.
Commerce version is 10.4.2
Regargds
Venkata Phani Kumar R
