If you can, then you should update to EPiServer.CMS.UI 10.6.0 or newer, where they fixed bug CMS-6328 which added a new field "remaining url"
I guess that will fix your problem
Hi Sebastian,
Great feature, that is awesome to know!
Unfortunately upgrading is not possible at the moment, since it will require a newer server than Windows Server 2008 R2 to support WebSockets protocol. Unless I'm wrong?
I think you can turn off the webscockets with adding this to app.config
<add key="Epi.WebSockets.Enabled" value="false" />
But not sure if that will help as it is an old server :/
Anyway, this is something I found from an old solution that was runing episerver 7.1, unfortanly it consist of two properties and maybe not the best solution, but it may help
[Display(Order = 6)]
[BackingType(typeof(PropertyUrl))]
public virtual Url Url { get; set; }
[Display(Name = "Filter", Description = "")]
public virtual string Filter { get; set; }
public Uri GetUrl()
var urlHelper = ServiceLocator.Current.GetInstance<UrlHelper>();
var url = EPiServer.Web.Mvc.Html.UrlExtensions.PageUrl(urlHelper, (Url ?? "").ToString());
var urlBuilder = new UrlBuilder(url.ToString());
if (!string.IsNullOrEmpty(Filter))
var filter = Filter;
if (filter.IndexOf('?') > -1)
filter = filter.Substring(filter.IndexOf('?'));
var query = HttpUtility.ParseQueryString(Url.Query);
var filterItems = filter.Split('&');
foreach (var item in filterItems)
var filterparts = item.Split('=');
query[filterparts[0]] = filterparts[1];
urlBuilder.Query = query.ToString();
return urlBuilder.Uri;
Thanks for the tip!
I've just tested with a basic EPiServer installation on the Windows Server 2008 R2 instance, and with that setting it seems to be running. There's no trace of errors in the console / network tab, so it seems the WebSockets is indeed disabled.
I have to mention that my original post is concerning the Create / Edit link feature within the Rich text editor.
I'm puzzled on I can link to content from the catalog and having a hash-value as well (as in, added to the URL).
This is the URL-scenario I'd like to have: http://www.example.com/da-dk/sport-og-idraet/fodbold/#!/480000=/Classic/
It's part of Angular's $locationService way of keeping track of values, and is this solution it corresponds to a pre-selected facet.
And here's what's possible at the moment:
As part of this UI, I would like to know how to add an extra (optional) field for adding my custom hash-value.
Best regards
Kristian
