Can you reproduce the issue on other machines as well? As reporting in Commerce is using ReportViewer 10 then there is very little we can do if VS2015 does not support that.
Hi Quan,
Thanks for the reply. I am not sure what is causing the issue. but i have got workarund adding and working with reports in newly created web project works. So i am working on new project and then copying it to commerce site.
Cheers
I am trying to add/update existing and new reports and whenever i try to add/update dataset then VS 2015 crashes. Tried many things but i am not able to make it work.
I am using EPiSever Commerce 9.9.1.0
Please help regarding this.
I am looking into EventViewer and getting errors. I have attached the txt file of event log
Application: devenv.exed__24.MoveNext()d__0.MoveNext()
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
at System.Signature.GetSignature(Void*, Int32, System.RuntimeFieldHandleInternal, System.IRuntimeMethodInfo, System.RuntimeType)
at System.Signature..ctor(System.IRuntimeMethodInfo, System.RuntimeType)
at System.Reflection.RuntimeConstructorInfo.GetParametersNoCopy()
at System.RuntimeType.FilterApplyMethodBase(System.Reflection.MethodBase, System.Reflection.BindingFlags, System.Reflection.BindingFlags, System.Reflection.CallingConventions, System.Type[])
at System.RuntimeType.GetConstructorCandidates(System.String, System.Reflection.BindingFlags, System.Reflection.CallingConventions, System.Type[], Boolean)
at System.RuntimeType.GetConstructorImpl(System.Reflection.BindingFlags, System.Reflection.Binder, System.Reflection.CallingConventions, System.Type[], System.Reflection.ParameterModifier[])
at System.Type.GetConstructor(System.Reflection.BindingFlags, System.Reflection.Binder, System.Type[], System.Reflection.ParameterModifier[])
at Microsoft.ReportDesigner.Design.DesignUtil.GetVenusObjectDataSources(System.Xml.Schema.XmlSchema[], System.IServiceProvider)
at Microsoft.ReportDesigner.Data.Local.DataSetSynchronizer+
at Microsoft.ReportDesigner.Data.Local.Dialogs.Pages.DataSetGeneralPage.LoadDataSources()
at Microsoft.ReportDesigner.Data.Local.Dialogs.Pages.DataSetGeneralPage.LoadData()
at Microsoft.ReportDesigner.Data.Local.Dialogs.DataSetDialog.OnLoad(System.EventArgs)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.ScrollableControl.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Form.WmShowWindow(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Form.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Control+ControlNativeWindow.OnMessage(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Control+ControlNativeWindow.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr, Int32, IntPtr, IntPtr)
and
Faulting application name: devenv.exe, version: 14.0.25420.1, time stamp: 0x57685d85
Faulting module name: KERNELBASE.dll, version: 10.0.14393.479, time stamp: 0x58256d37
Exception code: 0xe0434352
Fault offset: 0x000da832
Faulting process ID: 0x51c
Faulting application start time: 0x01d2814a557578fd
Faulting application path: C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE\devenv.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report ID: 597b9fa4-fd34-4885-976f-8837644e41a8
Faulting package full name:
Faulting package-relative application ID:
and
The description for Event ID 0 from source Application cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Error Handler Exception: System.ServiceModel.CommunicationException: There was an error reading from the pipe: Unrecognized error 109 (0x6d). ---> System.IO.IOException: The read operation failed, see inner exception. ---> System.ServiceModel.CommunicationException: There was an error reading from the pipe: Unrecognized error 109 (0x6d). ---> System.IO.PipeException: There was an error reading from the pipe: Unrecognized error 109 (0x6d).
at System.ServiceModel.Channels.PipeConnection.OnAsyncReadComplete(Boolean haveResult, Int32 error, Int32 numBytes)
at System.Runtime.AsyncResult.End[TAsyncResult](IAsyncResult result)
at System.ServiceModel.Channels.ConnectionStream.EndRead(IAsyncResult asyncResult)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.Net.Security.NegotiateStream.EndRead(IAsyncResult asyncResult)
at System.ServiceModel.Channels.StreamConnection.EndRead()
at System.ServiceModel.Channels.TransportDuplexSessionChannel.EndTryReceive(IAsyncResult result, Message& message)
at System.ServiceModel.Dispatcher.DuplexChannelBinder.EndTryReceive(IAsyncResult result, RequestContext& requestContext)
at System.ServiceModel.Dispatcher.ErrorHandlingReceiver.EndTryReceive(IAsyncResult result, RequestContext& requestContext) \r\n at System.Runtime.AsyncResult.End[TAsyncResult](IAsyncResult result)
the message resource is present but the message is not found in the string/message table
and
Fault bucket 129164286952, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: devenv.exe
P2: 14.0.25420.1
P3: 57685d85
P4: mscorlib
P5: 4.6.1586.0
P6: 575a1299
P7: 11cc
P8: 0
P9: System.IO.FileNotFoundException
P10:
\\?\C:\Users\Murtaza\AppData\Local\Microsoft\VSCommon\14.0\SQM\sqmdata.cvr
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER5868.tmp.WERInternalMetadata.xml
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_devenv.exe_8ba5fc7a74258245171925b8b8379ad522a75e0_12aa736e_1a867026
Analysis symbol:
Rechecking for solution: 0
Report Status: 0
Hashed bucket: 770350230c64839370b4f2a1f85bba7e
