Get Product from SEOURI
I am looking to create a function that will return "Product" for the given SEOURI.
So far I have reached to a point where I can get a product with matching SEOURI if it exists in Root Node.
var RootLink = referenceConverter.GetContentLink(referenceConverter.GetRootLink());
var Product= ContentLoader.GetChildren(RootLink , new CultureInfo("en-GB")).Where(pd => pd.SeoUri == SEOURIParam).ToList();
Is their a way I can search for Product in entire catalog, irrespective of what hierarchy level product exists.
I don't want to loop through each ProductListingNode to find the matching product.
Anurag
#185927
Dec 06, 2017 16:07
This is one place that you should use ICatalogSystem. It has a method named GetCatalogEntryByUriDto which is pretty fast and efficient. You can use it to load the CatalogEntryDto, then use referenceConverter to get the contentLink from CatalogEntryDto.CatalogEntry[0].CatalogEntryId, then load the content.
#185929
Dec 06, 2017 16:19
Hi Quan,
Thanks for your suggestion, that worked straight away.
Anurag
#185934
Dec 06, 2017 19:01
Hi Quan,
I just realise that irrespective of what "languageCode" I specify in _catalogSystem.GetCatalogEntryByUriDto(SEOUri, "en-GB"); or "en-CA" I always get "en-US", United State" product.
Do you know what could be the reason as because of the Variants are also "US" language?
Anurag
#186073
Dec 11, 2017 17:29
You don't even need to pass the languageCode, you just need to get the CatalogEntryDto which then you get the CatalogEntryId, then you need to pass "en-GB" into the IContentLoader.Get<EntryContentBase>(contentLink, CultureInfor.GetCultureInfor("en-GB"))
If you don't pass the CultureInfo into Get<T> then it always load the default language, in this case, en-US
#186074
Dec 11, 2017 17:35
With below code I can now get proper Product, but the variants are still coming for US version.
var productCatalogEntry = _catalogSystem.GetCatalogEntryByUriDto(SEOUri, ConversionHelpers.GetCultureCode(CountryCode));
var productContentLink = _referenceConverter.GetContentLink(productCatalogEntry.CatalogEntry[0].Code);
var productCatalog = _contentLoader.Get<BookProduct>(productContentLink, ConversionHelpers.GetCultureInfo(CountryCode));   // Correct Product is coming now.
var allRelations = _linksRepository.GetRelationsBySource(productCatalog.ContentLink); // This gives US variant even if "en-GB" is passed.
var bookVariantsList = allRelations.OfType<ProductVariation>().ToList();
var variantsList = new List<BookVariant>();
Any idea?
Anurag
#186075
Edited, Dec 11, 2017 18:04
Hi Quan,
I got the Variants correctly now, below is my code snippet, I did the samething with Variant that you suggested for Product.
var allRelations = _linksRepository.GetRelationsBySource<ProductVariation>(productCatalog.ContentLink);
foreach(var bookVariant in allRelations)
var variantCatalogEntry = _catalogSystem.GetCatalogEntryDto(bookVariant.Target.ID);
var variantContentLink = _referenceConverter.GetContentLink(variantCatalogEntry.CatalogEntry[0].Code);
var variantCatalog = _contentLoader.Get<BookVariant>(variantContentLink, ConversionHelpers.GetCultureInfo(CountryCode));
variantsList.Add(variantCatalog);
Anurag
#186077
Dec 11, 2017 18:34
