You are using the MetaObjects which cannot be used for test. Please refer https://github.com/episerver/Quicksilver/blob/master/Sources/EPiServer.Reference.Commerce.Site.Tests/Features/Cart/Services/CartServiceTests.cs
I'm trying to unit test some code that accepts an IOrderGroup. I need to create this construct in order to test this code. I'm using v10.4 of EpiServer.Commerce.Core.
Here's what I have currently. I was following what I found at this link - http://world.episerver.com/documentation/Items/Developers-Guide/Episerver-Commerce/8/Orders/Shopping-cart/...
When I get to the bottom and look at the orderGroup, while I have the correct number of LineItems and OrderAddresses, none of the data I set above can be found. Those objects are all completely empty with defaults/nulls for all their properties. Basically, I'm seriously struggling to build this construct and have anything I set be visible in the resulting orderGroup. I do not want to hit the database in any way. I just need to manually construct an IOrderGroup.
What am I doing wrong?
Tim
