Commerce Manager upgrade to 11.4, value cannot be null on initialization using EPiServer.Cms.UI.AspNetIdentity
We upgraded Commerce to 11.4 and implemented EPiServer.Cms.UI.AspNetIdentity on the login page.
That gave us this exception:
[ArgumentNullException: Värde får inte vara null.
Parameternamn: virtualPath]
   EPiServer.Shell.ShellInitialization.WaitForInitializeModules() +153
   EPiServer.Shell.<>c__DisplayClass11_0.b__1(Object sender, EventArgs args) +17
   System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) +0
   System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments) +128
   System.Delegate.DynamicInvokeImpl(Object[] args) +153
   EPiServer.Framework.Initialization.InitializationEngine.OnInitComplete() +241
   EPiServer.Framework.Initialization.InitializationEngine.ExecuteTransition(Boolean continueTransitions) +214
   EPiServer.Framework.Initialization.InitializationModule.EngineExecute(HostType hostType, Action`1 engineAction) +402
   EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +227
   EPiServer.Global..ctor() +103
   ASP.global_asax..ctor() in c:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root\8e4eadf3\4a4b2790\App_global.asax.9erted9t.0.cs:0
   System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0
   System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +197
   System.Activator.CreateInstance(Type type, Boolean nonPublic) +105
   System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1484
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +289
   System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +27
   System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +79
   System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +294
   System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +333
   System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +525
   System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +124
   System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +700
I then fond this article:
https://episerver.zendesk.com/hc/en-us/articles/115004119606-Shell-Initialization-Errors-in-Commerce-Manager-When-Updated-to-v10
Telling me to remove EPiServer.Cms.UI.AspNetIdentity.dll. If I remove it, my project wont compile. If I remove these:
EPiServer.Cms.Shell.UI.dll
EPiServer.UI.dll
EPiServer.Shell.UI.dll
EPiServer.Shell.dll
It fails because EPiServer.Cms.UI.AspNetIdentity.dll requires them.
Maybe you cant use EPiServer.Cms.UI.AspNetIdentity.dll in the Commerce Manager?
The Login.aspx.cs looks like this:
using Designonline.Shared.Identity;
using EPiServer.Cms.UI.AspNetIdentity;
using Microsoft.AspNet.Identity.Owin;
using System;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
namespace Designonline.Manager
    /// This is a custom code behind for the login page for CommerceManager
    /// to get OWIN authentication.
    /// We replace the original one as a build step when building this project.
    /// See the AfterBuild msbuild target in this files project file for details
    /// on how that is done.
    public partial class Login : Page
        private const string UserLoginFailureMessage = "Login failed. Please try again.";
        private ApplicationSignInManager _signInManager;
        protected void Page_Load(object sender, EventArgs e)
            Page.Header.DataBind();
            _signInManager = Request.GetOwinContext().Get>();
            LoginCtrl.Authenticate += LoginCtrl_Authenticate;
            if (IsPostBack)
                return;
            LoginCtrl.FindControl("ApplicationRow").Visible = Mediachase.Commerce.Core.AppContext.Current.GetApplicationDto().Application.Count != 1;
            LoginCtrl.Focus();
        protected void LoginCtrl_Authenticate(object sender, AuthenticateEventArgs e)
            var userName = ((TextBox)LoginCtrl.FindControl("UserName")).Text;
            var password = ((TextBox)LoginCtrl.FindControl("Password")).Text;
            var remember = ((CheckBox)LoginCtrl.FindControl("RememberMe")).Checked;
            var validated = _signInManager.PasswordSignInAsync(userName, password, remember, false).Result == SignInStatus.Success;
            if (validated)
                HandleLoginSuccess(userName, remember);
            else
                HandleLoginFailure(UserLoginFailureMessage);
        private void HandleLoginSuccess(string userName, bool remember)
            string url = FormsAuthentication.GetRedirectUrl(userName, remember);
            if (url.Equals(FormsAuthentication.DefaultUrl, StringComparison.OrdinalIgnoreCase) ||
                url.Contains(".axd") ||
                url.Contains("/Apps/Core/Controls/Uploader/"))
                url = "~/Apps/Shell/Pages/default.aspx";
            Response.Redirect(url);
        private void HandleLoginFailure(string pageMessage)
            LoginCtrl.FailureText = pageMessage;
Thanks!
/Kristoffer
#185272
Nov 14, 2017 8:49
The error was because the web.config was corrupt. Comparing web.config with QuickSilver 11.2.6 solved the problems.
/Kristoffer
#185281
Edited, Nov 14, 2017 10:34
