I created this test with Mspec, and it ran successfully:
public class Test : IntegrationTest
protected static ICart _cart;
Establish context = () =>
SaveCart();
_cart = SaveCart();
private static ICart GetCart()
var customer = Guid.Parse("CD8A9CCB-8550-4E4B-AC5F-5262E7B89491");
return OrderRepository.LoadOrCreateCart<ICart>(customer, "DefaultName");
private static ICart SaveCart()
var cart = GetCart();
string code = "New-test-variant_1";
var lineItem = cart.CreateLineItem(code);
lineItem.Quantity = 1;
lineItem.PlacedPrice = 100;
cart.AddLineItem(lineItem);
var cartLink = OrderRepository.Save(cart);
return OrderRepository.Load<ICart>(cartLink.OrderGroupId);
It Should_save_the_cart_successfully = () => _cart.ShouldNotBeNull();
Is this the same code which throws exception for you?
Yes, (depending on what is OrderRepository in your code). In mine it is injected IOrderRepository, suppose it's the same.
The code goes through ok first time, and cart is saved and that LineItem is in it when I look for it in Manager. Then on next call it raises exception about InStockQuantity being null.
Only additional thing I managed to notice is that on the first run of the snippet, the line item is of a type Mediachase.Commerce.Orders.LineItem (when Cart is inspected just before the save). After first Save is executed, that line item becomes EPiServer.Commerce.Order.Internal.InMemoryLineItem.
Just before second Save this is returned by GetAllLineItems()
+ [0] {EPiServer.Commerce.Order.Internal.InMemoryLineItem} EPiServer.Commerce.Order.ILineItem {EPiServer.Commerce.Order.Internal.InMemoryLineItem}
+ [1] {Mediachase.Commerce.Orders.LineItem} EPiServer.Commerce.Order.ILineItem {Mediachase.Commerce.Orders.LineItem}
The InMemoryLine item doesn not carry InStockQuantity with it, so it breaks with constrained not-NULL value when cart is Saved second time.
- [0] {EPiServer.Commerce.Order.Internal.InMemoryLineItem} EPiServer.Commerce.Order.ILineItem {EPiServer.Commerce.Order.Internal.InMemoryLineItem}
Code "New-test-variant_1" string
DisplayName "New test variant" string
InventoryTrackingStatus Disabled Mediachase.Commerce.Inventory.InventoryTrackingStatus
IsGift false bool
IsInventoryAllocated false bool
LineItemDiscountAmount 0.00 decimal
LineItemId 11071 int
OrderLevelDiscountAmount 0.000000000 decimal
PlacedPrice 100.000000000 decimal
+ Properties Count = 7 System.Collections.Hashtable
Quantity 1 decimal
ReturnQuantity 0 decimal
+ Non-Public members
Just for sake of reference, the one that was added in second run is like this
- [1] {Mediachase.Commerce.Orders.LineItem} EPiServer.Commerce.Order.ILineItem {Mediachase.Commerce.Orders.LineItem}
AllowBackordersAndPreorders false bool
BackorderQuantity 0 decimal
Catalog "" string
CatalogEntryId "New-test-variant_1" string
CatalogNode "" string
ConfigurationId "" string
+ ConnectionHandler {EPiServer.ServiceLocation.Injected<Mediachase.Data.Provider.IConnectionStringHandler>} EPiServer.ServiceLocation.Injected<Mediachase.Data.Provider.IConnectionStringHandler>
+ Created {29.01.2017 21.30.48} System.DateTime
CreatorId null string
Description "" string
DisableSync false bool
+ Discounts {Mediachase.Commerce.Orders.LineItemDiscountCollection} Mediachase.Commerce.Orders.LineItemDiscountCollection
DisplayName "" string
ExtendedPrice 0 decimal
+ FieldStorage Count = 7 System.Collections.Hashtable {Mediachase.MetaDataPlus.ObservableHashtable}
Id -7 int
InStockQuantity 0 decimal
InventoryStatus 0 int
IsGift false bool
+ ItemArray {object[7]} object[]
+ LineItemCalculator {EPiServer.ServiceLocation.Injected<EPiServer.Commerce.Order.ILineItemCalculator>} EPiServer.ServiceLocation.Injected<EPiServer.Commerce.Order.ILineItemCalculator>
LineItemDiscountAmount 0 decimal
LineItemId -7 int
+ LineItemOrdering {29.01.2017 21.30.48} System.DateTime
ListPrice 0 decimal
MaxQuantity 100 decimal
+ MetaClass {Mediachase.MetaDataPlus.Configurator.MetaClass} Mediachase.MetaDataPlus.Configurator.MetaClass
MinQuantity 1 decimal
+ Modified {29.01.2017 21.30.48} System.DateTime
ModifierId null string
ObjectState Added Mediachase.MetaDataPlus.MetaObjectState
OldQuantity 0 decimal
OrderFormId 0 int
OrderGroupId 0 int
OrderLevelDiscountAmount 0 decimal
OrigLineItemId null int?
+ Parent {Mediachase.Commerce.Orders.OrderForm} Mediachase.Commerce.Orders.OrderForm
ParentCatalogEntryId "" string
PlacedPrice 100 decimal
PreorderQuantity 0 decimal
ProviderId "" string
Quantity 1 decimal
ReturnReason "" string
ShippingAddressId "" string
+ ShippingMethodId {00000000-0000-0000-0000-000000000000} System.Guid
ShippingMethodName "" string
Status "" string
+ SystemFieldStorage Count = 34 System.Collections.Hashtable
WarehouseCode "" string
+ Static members
Obviously InStockQuantity is 0 (which is correct for test SKU) which is not NULL.
I can confirm that in QuickSilver 10.2.3. this saving and then saving updated cart works. I have some problem obviously, but am wondering where to start looking for solution to, bcs upgrade process didn't raise any errors. Hm.
Comparing to QuickSilver shows that it works with Seriazable cart, adding SeriazableLineItem, that contains full set of properties including InStockQuantity. So this InMemoryLineItem is pretty suspicious, but I don't know where did that come from.
To isolate the issue I have created a TestController that I call manually:
public ActionResult Index()
var cart = LoadOrCreateCart(Mediachase.Commerce.Orders.Cart.DefaultName);
var lineItem1 = cart.CreateLineItem("test-sku123");
lineItem1.Quantity = 1;
lineItem1.PlacedPrice = 100;
cart.AddLineItem(lineItem1);
_orderRepository.Save(cart);
var content = new ContentResult
Content = string.Format("<h1>Nr of items in cart: {0}</h1>", cart.GetAllLineItems().Count())
return content;
private ICart LoadOrCreateCart(string name)
var customer = Guid.Parse("BD7F334C-2D8A-4836-BB7F-2D3302216D20");
var cart = _orderRepository.LoadOrCreateCart<ICart>(customer, name, _currentMarket);
return cart;
I was unable to reproduce this problem on 10.2.3 (QS), with old or new cart system.
Nr of items in cart: 6
Is there anything special about test-sku123?
No, it's a clean Variation without any properties.
If I turn on SQL Profiler I can see that on 2nd add it calls stored procedure "ecf_LineItem_Update" with @InStockQuantity=NULL. Do you have any idea what could be causing this?
I originally thought it was a database issue, but since I can reproduce it in a fresh db it has to be somthing in the solution.
And: If I run the same code using the old api, it works with no errors. Here is the code:
var custmerGuid = Guid.Parse("9A9510FB-8E32-43BB-BC14-6C13B6A47BDC");
Cart cart = OrderContext.Current.GetCart(Cart.DefaultName, custmerGuid);
//Get first orderform or create on if no exists
var orderForm = GetOrderForm(cart);
var lineItem = new LineItem
Code = "test-sku123",
Quantity = 1
orderForm.LineItems.Add(lineItem);
//now save the changes to the database
cart.AcceptChanges();
SKU type doesn't play a role in reproducing the bug. I have just put "ninja" (that doesn't even exist as object) for the Code and saved the cart (first time). Cart is visible in Manager.
When cart is updated and Save called again, same SQL exception breaks with InStockQuantity NULL message.
So the very sku type is not causing it. It breaks the same for variants that work CartHelper (before and after upgrade), test sku that is an empty type (like on beginning of this thread), or just putting any string for code (bcs validation is not called).
Can you zip the project (I assume you can produce it on Quicksilver) and send it to me directly via email.
I suspect this is an urgent matter and we are willing to help - but we need to reproduct the problem first.
Regards,
/Q
I meant "reproduce" - can you replace one of the controller in Quicksilver with your code to see if it happens?
We cannot reproduce this on QuickSilver (as stated in the original post).
OK I missed that. As I can't reproduce this issue, the usual response - contact our developer support service. When we have a bug report we will act on it ASAP.
Hi @Mari,
I just guess your issue when you post "it's a clean Variation without any properties" and code, the reason causes this should related to inventory service.
Not sure but when creating a variation - for testing - we need to add an inventory record for that variation. If not, it might be removed when adding to cart.
Hope this help.
/Son Do
For sake of the test of saving, validation was not called so line item wasn't removed. The problem is solved by upgrading from start.
After upgrading to 10.2.3 we are experiencing _orderRepository.Save(cart); crashing after cart is updated and saved again. The exception comes from SQL: Cannot insert the value NULL into column 'InStockQuantity', table 'NNNNNNNNNN_10.dbo.LineItem'; column does not allow nulls. UPDATE fails.
For first there is no setting of InStockQuantity by us, but it is passed as not null and Save goes OK. Next time same code is run, it fails. For sake of testing there is one simple entry type:
One entry of that type is created in catalog UI and then this shippet of code is executed:
where GetCart returns always the same named cart
First time cart is saved with no problems, then second call causes exception:
If somebody has an idea what to look for as a reason, it will be much appreciated
