Issue with saving ShippingProviderParameters (Version: 9.11 (build: 1)
Hello all
Maybe somebody saw same error. While saving parameters of ShippingProvider I am getting following exception
_____________________________________________________________________
Column 'ShippingOptionParameterId' is constrained to be unique.  Value '3' is already present.
Exception Details: System.Data.ConstraintException: Column 'ShippingOptionParameterId' is constrained to be unique.  Value '3' is already present.
Source Error:
Stack Trace:
[ConstraintException: Column 'ShippingOptionParameterId' is constrained to be unique.  Value '3' is already present.]
   System.Data.Common.DbDataAdapter.UpdatedRowStatusErrors(RowUpdatedEventArgs rowUpdatedEvent, BatchCommandInfo[] batchCommands, Int32 commandCount) +1697124
   System.Data.Common.DbDataAdapter.UpdatedRowStatus(RowUpdatedEventArgs rowUpdatedEvent, BatchCommandInfo[] batchCommands, Int32 commandCount) +53
   System.Data.Common.DbDataAdapter.Update(DataRow[] dataRows, DataTableMapping tableMapping) +2350
   System.Data.Common.DbDataAdapter.Update(DataRow[] dataRows) +268
   EPiServer.Data.Providers.SqlTransientErrorsRetryPolicy.Execute(Func`1 method) +66
   Mediachase.Data.Provider.SqlDataProvider.SaveRows(DataCommand command) +1231
   Mediachase.Commerce.Storage.DataHelper.SaveDataSetSimple(DataCommand cmd, DataSet set, String[] tables) +66
   Mediachase.Commerce.Orders.Managers.ShippingManager.SaveShipping(ShippingMethodDto dto) +388
   Mediachase.Commerce.Manager.Order.Shipping.ShippingOptionEdit.EditSaveControl_SaveChanges(Object sender, SaveEventArgs e) +634
   Mediachase.Commerce.Manager.Core.SaveControl.OnSaveChanges(Object sender, EventArgs e) +61
   System.Web.UI.WebControls.Button.OnClick(EventArgs e) +11802193
   System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +150
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1735
When I look into [dbo].[ShippingOptionParameter], table is empty. On repeated attempts to save, it just increases the identity that bounced, but doesn't write to the table. I tried to RESEED it, and it behaves the same, just throws with id being taken from 1 and on.
I also looked into it with SQL profiler, and this is what it attempts to do
exec sp_executesql N'INSERT INTO [ShippingOptionParameter] ([ShippingOptionId],[Parameter],[Value]) VALUES (@ShippingOptionId,@Parameter,@Value); SELECT SCOPE_IDENTITY() AS [ShippingOptionParameterId]',N'@ShippingOptionId uniqueidentifier,@Parameter nvarchar(50),@Value nvarchar(255)',@ShippingOptionId='94449DF4-4C9E-45F9-9AFF-A3F07CC96247',@Parameter=N'Consignor.IsProduction',@Value=N'false'
When I alter it to
	('[MyGuidOptionId here]','[MyValueHere]','false');
That one row get's inserted. Now back to the form where I have couple of parameters to save. Did anyone see such exception, what might be the reason?
Thanks in advance
#157813
Sep 22, 2016 15:59
It seems to me that you are using a custom shipping gateway? Is it possible to post its code here?
/Q
#157867
Sep 23, 2016 14:28
