It would help if you can take the screenshots of your campaign, promotion settings. And what do you have in MarketingContext.Current.GetCustomerSegments(accountId, organizationId)?
Segment is a less known concept of Commerce btw - so it might take some times before you get answers :)
Regards,
/Q
Hi Quan,
I have created a segment and mapped it to Campaign. This Campaign I have selected while creating promotion.
I am not able to attach the screenshots here.
MarketingContext.Current.GetCustomerSegments(accountId, organizationId) --> is returning 2 rows which contains 7,9. But the segment selected in campaign is "PM OLB" which is 10. This is returning wrong results.
organizationId is also not there for the user.
The below details are from segment table
SegmentId Name
7 ECOM
8 OLB
9 all
10 PM OLB
In CalculateDiscountActivity, Do we require CustomerProfileWrapper?
CustomerProfileWrapper profile = SecurityContext.Current.CurrentUserProfile as CustomerProfileWrapper;
if (profile != null)
SetContext(MarketingContext.ContextConstants.CustomerProfile, profile);
CustomerContact customerContact = CustomerContext.Current.GetContactForUser(user);
if (customerContact != null)
SetContext(MarketingContext.ContextConstants.CustomerContact, customerContact);
Guid accountId = (Guid)customerContact.PrimaryKeyId;
Guid organizationId = Guid.Empty;
if (customerContact.ContactOrganization != null)
organizationId = (Guid)customerContact.ContactOrganization.PrimaryKeyId;
SetContext(MarketingContext.ContextConstants.CustomerSegments, MarketingContext.Current.GetCustomerSegments(accountId, organizationId));
Manjeera T
Hi Quan,
I found like the below is failing for getting segments.
return ((IExpressionValidator)MarketingContext.Current.ExpressionValidatorClassInfo.CreateInstance()).Eval(key, expr, context);
Any response on this is much appeciated.
Thanks in Advance
Manjeera T
Hi Team,
I am facing issue in applyign discounts based on segment mapped to campaigns
The below line is returning object reference error at Mediachase.Commerce.Security.SecurityContext.GetCurrentUserProfile() in CalculateDiscountActivity.cs
It is a disconnected architecture. We are using webapi to create purchaseorder and apply promotions.
Is there anyway to get the CustomerProfileWrapper
I tried the below way but is returning null
var profile = Mediachase.Commerce.Customers.Profile.CustomerProfile.Create(customerContact.UserId) as CustomerProfileWrapper;
Also Please confirm if the below code is used for mapping to segments while calculating discounts.
Thanks in advance
Manjeera T
